My brother multi purpose machine needed new inks which were installed but they were rejected. I am now informed the machine cannot be fixed. It is only 2 1/2 years old. I now have paid for the new in
Can I obtain another MFC which will take the cartridges I have just purchased. An inexpensive one.
    Master:
  • 505 Answers
Yes u can but have no idea on cost not much ill say.
Posted on Sep 05, 2008
My Brother LC61, bought in Nov.2010, won't print black. Recently replaced black ink along with all color inks...replaced black ink again when it quit printing...still won't work. Machine whirs...
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Brother Multi-Function Center MFC-240C...
Brother DCP-115C Printer: "No Ink" message continues even after old ink cartridge (still some ink!) is replaced with a new one.
Reset the printer to factory settings
Turn off the printer. and turn it on again.
If still not working
Take out the cartridges, turn off the printer
Turn on the printer and put the cartridge again.
Oct 27, 2008 | Office Equipment & Supplies
My machine is printing but there is nothing printed on the paper when it comes out and all ink is new
First make sure you have removed any packing tape from ink cartridge.
Second look into ink cartridge slot on printer and make sure nothing is blocking installation of ink cartridge.
Be aware that your Brother machine is designed to stop ALL printing operations when any of the ink cartridges are empty.
Mar 02, 2011 | Brother Multi-Function Center MFC-240C...
What do you do when you have changed your ink cartridges but the machine is saying that there is no cartridge and please install?
if you are using a refilled cartridge, the printer will not accept them or if you are using a non brother cartridge, you need to install the proper cartridge. and you are using brother cartridge:
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
if the message 'No cartridge ' still displayed:
  1. remove all the cartridge
  2. install one by one
  3. if there is a defective one you can find it so you need to reinstall a new cartridge
Dec 24, 2010 | Brother Multi-Function Center MFC-240C...
Black not printing on a Brother MFC-290C
in the printer display try head cleaning option, there must be something blocking the cartridge. hope this helps
Jul 17, 2009 | Brother Multi-Function Center MFC-240C...
HELLO, MY WIFE BOUGHT A BROTHER MFC-685CW.WE Cant even get passed getting the buttons to work. when you depress any key it just beeps and does nothing. We have not even got to installing the drivers yet...
Most multi purpose devices such as the Brother MFC-685CW has some sort of transport lock. This could either be plastic lugs/screws or nuts strategically located. In some versions, these could simple be plastic colored tape. The initial set-up instructional pamphlet should indicate where they are.
Your particular model has also yellow protection caps/tabs in place when transported without the ink, have you checked those?
Alternately, you can try a reset by simply unplugging the unit from the mains for a couple of hours.
Not knowing where you are, I couldn't forward a contact number. However, you can try here and click on your region. Alternately, pls try:
Brother International Canada, Toll-free: 1-800-361-6466
http://www.brother-usa.com/; Support Phone Number: 1-800-284-4329
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 23, 2008 | Computers & Internet
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
No ink display on brother mfc240c
First make sure that you are using Brother Cartridges, their machines are very sensitive to using generic ink. Put a brand new set of ink in the machine. Pull all the old cartridges out and put all new cartridges in. If this does not resolve the issue contact Brother, they are very good about helping their customers.
Jan 02, 2008 | Brother Multi-Function Center MFC-240C...
Installing new cartridges and showing empty
Is this a genuine Brother cartridge or a compatible/refilled cartridge? Inside, at the rear of the cartridge there is flag which when full blocks a sensor in the machine indicating the cartridge is full - with some compatible and refilled cartridges the flag may not be set correctly so the sensor sees that there is no ink in the cartridge. As a temporary fix place some black tape over the rear of the cartridge where the sensor arm is.
Sep 09, 2007 | Brother Multi-Function Center MFC-240C...
jasbo
jasbo
