Question about Samsung AW0503B Air Conditioner
Window Unit doesn't cool
I purchased a 6,000 btu unit 2 weeks ago and the unit froze ...with lots of ice coming out the front....I thawed it out with a blow dryer (melted a small place on the front of the unit) and now it doesn't cool. What do I do?
    Novelist:
  • 166 Answers
Peace,
ngafm at your service,
You do know that you have a one year service warranty with all major appliances you buy?
You do not have to do anything ! Just call service and have your sales receipt ready to give them the sales information!
I think this is the easyest thing to do and i's free if you bought it new!
ngafm
please rate me before you sign of!
Posted on Sep 05, 2008
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
How can I defrost my Kitchenaid Superba Freezer without unplugging the entire unit?
the air from the freezer is what cools the fridge so no way to separate the cooling process for defrost
Apr 24, 2017 | KitchenAid Superba KSRS27CN Side by Side...
My window a/c compressor won't turn off, thus making the room extremely cold.... Kenmore 17,5/18000 btu model 580.73189300. Earlier, the front grill was iced over and i have since thawed it out (the 1st...
the unit running all the times sounds like a faulty thermostat which is saying its still hot when its not.try finding thermostat make sure all plugs are in all the way on the circuit board. does it run all the time on heating? the iceing up would just because its running all the time. i
Nov 10, 2010 | Kenmore 75180 Wall/Window Air Conditioner
My window ac shut completly off.There was barly air coming out...then it shut off and there was ice in it.
If the A/C was running constantly, even when the temperature has dropped outside, the a/c unit can freeze up. Just let it thaw out, the ice will melt. Then turn it back on but turn it on at a higher temperature. Then ease it to the lowest temperature or highest cool setting. You probably have a clogged filter in the front of the a/c unit which takes in the air. These can be cleaned.
Aug 07, 2010 | Kenmore 6000 BTU Single Room Air...
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Aug 02, 2009 | Heating & Cooling
Panasonic Inverter aircon E24DKR icing up inside unit
Yes, if the filters are clean, the coils are clean, and it is still freezing up in cooling mode, then it is low on refridgerant.
Jan 14, 2009 | Carrier 52PQ307 Wall/Window Air...
Bought an airconditioner about two weeks ago,the unit is 26.000 btu and is not performing the way it should be.
Hey,, have you checked ot the back coils from the inside out? This unit should cool enough to hang meat! If dirty and plugged, itwon't remove heat and sends it back in the front coils,,,(see where I'm going with this !) A window unit should have at least 20*- 25* temp. different from the air blowing out the front coils and the air sucking in! (If less than 15*, low on freon!) Thank-you-very-much!
Aug 26, 2008 | Friedrich Heating & Cooling
How large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
if this helps please vote me a fix ya
Jul 21, 2008 | Heating & Cooling
Have a coleman evcon heating & cooling furnace froze up had ice on coil / top of unit. Husband cut the unit off to thaw out not the unit will not come back on.
Freon (charge) is low. Contact a service man with the proper gauges to check theunit. It will have to be evacuated, nitrogen pressure tested, and then recharged.. Depending on the size of the unit, this cold be about 200-400$.
Jul 07, 2008 | Heating & Cooling
Samsung AW0503B Air Conditioner Logo
82 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
