Compaq Presario 1700 Laptop screen flickers and locks up
When setting idle in bios setup after a while the laptop screen goes black and seems to be locked up. I can boot it up to install XP, but after a while about half through the install screen starts to flicker then goes normal then will flicker until finally either goes black or to the Compaq logo screen and seems to be locked up. I can hold power button and power down though??? What is up with this thing. I did take keyboard loose and fan comes on at boot up and then turns off and never seems to come back on before it locks up or whatever.
    Brigadier General:
  • 5,158 Answers
It sounds possibly that it is going into hibernation. a single press of the power button should bring it back alive.
also feel the bottom of the laptop.... if it is getting close to meltdown you need to clean the dust and dirt from the heatsinks. the fan area may appear to be clear but all the junk gets blown against copper heat sinks so you need to remove the covers to get at it.
Robert
Posted on Sep 05, 2008
Hi please help me, my compaq presario 1700 flickers then i dont see anything the screen turns into black, but the sound is ok and its not hibernating, and overheating, but sometimes it comes back to normal...
This is most likely an hardware related issue in which case you need to get it checked. To narrow the issue, you can try hooking up your laptop to an external monitor if possible and see if it does the same. If not, then there's probably an issue with the displays internal connectors. You can also try powering your laptop with only the power cable attached and without the battery, then reset all power management settings. If the problem goes away then it's probably a power management issue.
Apr 18, 2011 | HP Compaq Presario 1700T Notebook
When Booting My Compaq Presario 2100 It Goes To A Black Screen And Ask Enter Drivelock Password .Ihave Not Used Any Passwords .Can't Get Pass This ,Any Ideas? Richard
Try entering your "Setup" or "BIOS" and find the area for "Security". From there you should be able to change the password that it has on it. If your "Setup" or "BIOS" has a password on it and you don't know it, then it is likely that your laptop is worthless to you now. Unlike desktop computers that usually have a BIOS or CMOS reset on the motherboard, laptops seldom have this option. If your's has a RESET on it then it will likely be a little pin-hole on the bottom of the laptop that says RESET next to it.
Aug 22, 2010 | Compaq Presario Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
System restore disk for HP compaq Presario 1700 help
hi, you may need to set your laptop to boot from the cd/dvd. you will need to enter the bios and check the boot priority. power the laptop as soon as you power on press either F2 or F10 to enter the bios (you have to be pretty quick with the F2 button). once in the bios look for the heading BOOT or BOOT PRIORITY F5 or F6 willchange the boot order.
hope this helps
Feb 22, 2009 | HP Compaq Presario 1700T Notebook
Lcd hdtv is hooked up to laptop but it is every 10 sec gos black
if theres nothing happening on ur pc like same as tv its probably the tv config ...
check tv setup
check tv screen saver..if it disabled it would explain why screen black...
could try checking power settings in pc(screensaver properties)
Dec 10, 2008 | HP Compaq Presario V6000T Notebook
Compaq presario 1700 LCD issues
i have the exact same problem. try connecting the laptop to an external VGA screen. if it works, then the problem is most likely a loose cable (connector). It turns out that the connector (which connects the motherboard or gfx card to the LCD screen) on my laptop is torn and cut. see if u have the same problem. this link might help u check out ur problem:
http://www.laptopparts101.com/lcd-screen-video-cable/
Nov 21, 2008 | Compaq Presario 1700 Notebook
Computers & Internet Logo
447 people viewed this question
David Payne
David Payne
