Question about Polaroid PhotoMax PDC 640 Digital Camera
Transfering pictures using the FlashPath Floppy Disk Adapter?
How do I transfer pictures from my camera to my computer using the FlashPath Floppy Disk Adapter?
    Master:
  • 450 Answers
To transfer pictures: 1. Remove the memory card from the camera. 2. Insert the memory card into the floppy disk adapter. Make sure that you insert the memory card into the adapter with the gold side of the memory card facing you and to the right and the silver side of the adapter facing away from you. 3. Insert the floppy disk adapter into the diskette drive on your computer. 4. Double-click the PhotoMAX shortcut on your desktop to open the software. 5. Click Get Photo. 6. Click Album or FlashPath. 7. Click Downlod from FlashPath. The images appear as thumbnails on the album manager window. 8. Double-click the image that you want to edit. The image appears in the image tray. 9. Remove the FlashPath Floppy Disk Adapter from the diskette drive when you are done.
Posted on Sep 21, 2005
SOURCE:
Data backup Satellite T2135CS
Even when you can connect both computers, you need a program to transfer the data. Does you'd DOS computer still have a floppy disk?
because it would be much easier to set the files over with a floppy.
If your laptop still would have a serial connection port, you could use that too. But as I said, for both computers you need a communications program
May 22, 2014 | Toshiba Satellite T2135CS Laptop Universal...
My memory card is full and I want to transfer to my computer. I tried to transfer to internal memory but it says there isn't enough space. Anyway to transfer all at once instead of tagging individual...
Connect you camera to the computer using the USB cable. It will be shown as a removable drive(If the autorun is enabled windows should list the option to transfer pictures.Choose this option if it does so). Open the drive and and transfer the pictures to your computer.
Hope this helps,
Sai.
Dec 24, 2009 | Kodak ZD710 Digital Camera
Canon digital camera solution disk
it is very simple when u connect ur camera to pc through data cabel u seen dat dere is some driver automatically u need not ny software to connect to ur pc...
if u r using windows xp....
when u connect it automatically ask u to copy images......
if it not ask then u hv to transfer ur picture through cardreader...
connect cardreader wid pc n copy all pics..
but it can be used to transfer only ur memorycard pictures..
Jun 19, 2008 | Canon PowerShot SD600 Digital Camera
Copy files from old computer and transfer to new computer
Although Vista comes with an Easy File Transfer Wizard it is not compatible with Windows 98.
You will need a CD burning program such as Nero Burning Suite or Creative CD Writer or here is a link to a FREE one.
May 08, 2008 | Computers & Internet
Downloading pictures onto computer
There are Three primary ways to do this...
1. use a (usualy supplied) data cable... normaly a USB cable... it connects to your computer/laptop , Use a Photo utility program to "find" the camera. You should be able to view the pics stored in the camera.
2. If the camera pics are stored on a sim card then simply put that card in a multi card reader... (very inexpensive to purchase and standard on some late model PC's) and in most cases you can pull the pics directly from the card.
3. Take the camera directly to walmart or walgreen's photo station and they usualy can pull the pics directly from it.
give me some more info and I maybe able to give detailed help...
mod# of camera and what model/make of your PC.
Apr 08, 2008 | Computers & Internet
How do I the delete images so I can re-use the memory card?
To delete photos from the SmartMedia memory card in your camera, you must first download them to your computer. Follow this procedure to transfer your photos from the camera to your computer: 1. Make sure that your PDC 640 is connected to your computer and both are turned on. The "PC" icon should appear on the status panel on the top of the camera. 2. Open the PhotoMAX application on your PC. 3. Click Get Photo. Note: If you are using PhotoMAX Pro to transfer pictures, you need to select PDC 640 Camera from the Select Source dialog box (select File > Acquire > Select Source), and then select File > Acquire. 4. Click Album or flashPath. 5. Select the album in which you want to save your images, or click New Album to create a new album. 6. Click Camera or Scanner. 7. Select PDC 640 from the Sources list on the Select Source window, and then click Select. The PDC 640 Twain Driver window opens. 8. Click Get All to transfer all the images in the camera memory to your computer, or select the images you want to transfer to your computer and click Get Selected. The images are transferred to the selected album, which is located in the PhotoMAX Albums folder. The PDC 640 Twain Driver window closes. 9. To edit a picture, double-click the image in the album that you want. The image appears in the image tray.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
How do I retrieve pictures and voice messages?
The camera uses a high speed connection to retrieve images and sounds. Simply connect the serial cable to the camera and PC, and the images and voice messages from the camera's internal memory or optional SmartMedia card are transferred to the computer at up to 115 Kbps. User's can also use an optional 3.3V SSFDC or SmartMedia card adapters to transfer the images directly from a SmartMedia adapter interface to their computer's hard disk drive. Also in development is a 3.5" diskette drive adapter for users to retrieve images directly from their diskette drive to their computer's hard drive.
Sep 13, 2005 | Epson PhotoPC 550 Digital Camera
Main advantages
* Super high capacity storage/ floppy disk compatible The Panasonic PV-SD4090 and PV-SD5000 digital cameras offer super high capacity storage on a 120MB SuperDisk™ Diskette for up to 1500 shots on the PV-SD4090 (Up to 1000 on PV-SD5000). Also, both cameras are floppy disk compatible. * USB Port/External SuperDisk™ Drive Both cameras come equipped with a USB port so you can quickly and easily transfer images from either a SuperDisk™ Diskette or floppy disk (using the included USB cable) to your computer, even if your computer does not come equipped with either a SuperDisk™ Drive or floppy disk drive. In addition, images and data can be transferred from your computer to the camera using the included USB cable*. This lets both the PV-SD4090 and the PV-SD5000 digital cameras function as an external SuperDisk™ Drive so you can easily archive your images or backup all your data (i.e. Excel, PowerPoint files). * Inexpensive media Panasonic SuperDisk™ digital cameras use SuperDisk™ Diskettes or 1.44MB floppy disks. SuperDisk™ Diskettes cost approximately $10.00 each (suggested retail price), which is far less expensive than comparable CompactFlash or SmartMedia cards. * Motion image recording with audio The PV-SD5000 can record up to 12 seconds of motion images with audio (the PV-SD4090 stores up to 10 seconds) using the popular QuickTime™** format, so you can easily send motion image files to friends and family. * TIFF recording (PV-SD5000 only) TIFF format recording allows you to take uncompressed images with greater clarity and detail. * Comes with a complete package of accessories, including: 1. 120MB Panasonic SuperDisk™ Diskette 2. Rechargeable lithium ion battery pack 3. AC adapter charger 4. DC cable 5. A/V cable 6. USB cable 7. Camera strap 8. Software CD-ROM including Adobe® PhotoDeluxe® editing software *Requires Microsoft™ Windows® 98 preinstalled PC with USB port, Windows® 2000 PC with USB port, iMac® or Power Macintosh® G3 or G4 with USB port and Mac OS version 8.1 or later. Windows® 2000 driver for the PV-SD4090 is currently available on this website. Software for the PV-SD5000 will be available in the near future. **QuickTime and the QuickTime logo are trademarks used under license. QuickTime is registered in the U.S. and other countries.
Sep 04, 2005 | Panasonic Palmcam PV-SD5000 Digital Camera
Main advantages
Sep 04, 2005 | Panasonic Palmcam PV-SD4090 Digital Camera
Pictures not transferred to the computer
The cause and solution may include one of the following: The AC adapter or USB cable is not securely connected. Check the connections, and then try transferring pictures again. Kodak EasyShare software is not installed. Install the software. There are too many programs running on the computer. Close all software programs and try transferring pictures again. The camera was removed from the dock during picture transfer. Replace the camera on the dock, and press the Transfer button. The Transfer button was not pressed. Press the Transfer button.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Polaroid PhotoMax PDC 640 Digital Camera Logo
115 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
