Question about Polaroid PhotoMax Fun 320 Digital Camera
What is an ISSET_SE error?
While attempting to install my PhotoMAX software, I received an "ISSET_SE" error. What's wrong?
    Master:
  • 450 Answers
When you attempt to install the PhotoMAX software from your CD-ROM drive, you may receive the following error message: "ISSET_SE caused a general protection fault in module (FILENAME) at (ADDRESS) where (FILENAME) is the name of the program file you are trying to run, and (ADDRESS) is the memory address at which the error occurs." This is an error that can occur with Windows 95 and 98 under certain conditions -- it does not indicate an error with the PhotoMAX software. This (error message) can occur if any of the following conditions exists: * Norton AntiVirus version 4.04 is installed and Norton AutoProtect is enabled. * You use LiveUpdate for Norton AntiVirus to download an updated version of Norton AntiVirus. * Microsoft IntelliPoint software is installed on your computer, and the Point32 program is currently running. * Microsoft IntelliMouse or Microsoft IntelliMouse Trackball software is installed on your computer, and the Mswheel program is currently running.
Posted on Sep 21, 2005
What do i need to install Photomax with Vista?
The problem can be found where the DL for the program hasn't installed and as a result the software reports an error. Delete the program, fresh install in a new location and then try running it again. If it continues to crash, check your security settings for program installation to ensure this is not set too high thereby prohibiting the running of the program. If you are using an illegal copy of the program then the game is up and you will need to purchase the full program. If you continue to have problems and you do actually own the software then get in touch with the software company and let them assist you.
**You need either ubunthu or fedora 8
Nov 07, 2010 | Polaroid PhotoMax Fun 320 Digital Camera
"No camera is connected" -- USB connection
The "No camera is connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
PhotoMAX software CD?
# Try inserting a different CD to make sure your CD-ROM drive is working. If the CD-ROM drive cannot read any CD, contact your computer manufacturer -- it's possible that your CD-ROM drive is not working properly. # Make sure the PhotoMAX CD is clean, with no fingerprints, dirt, or smudges. If necessary, you can clean the CD with a lint-free cloth and warm water. Dry with a hairdryer on the cool setting. Make sure the CD-ROM is completely dry before attempting to load it again.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Windows NT4 and Windows 2000
Windows 2000 A new camera TWAIN driver (version 0.1) compatible with Windows 2000 is now available for download. The new TWAIN driver will allow photo transfer using most image viewing or editing programs that are TWAIN compatible. NOTE: In order for the version 0.1 driver to work correctly, the PhotoMAX software must also be compatible with Windows 2000. The PhotoMAX SE software originally included with the Fun! Flash 640 is not compatible with Windows 2000. If you use your camera and computer with the original PhotoMAX SE software, contact the Polaroid Parts Department for more information about purchasing a PhotoMAX software upgrade. Windows NT4 No TWAIN driver is available for use with Windows NT4.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Can I use the Fun! 620 digital camera with Windows XP?
Yes -- by installing updated camera drivers , you should be able use your Fun! 620 camera with a computer running Windows XP.
Sep 14, 2005 | Polaroid PhotoMax Fun 620 Digital Camera
Can I use the PDC 1100 camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will no longer be able to use a USB port to download your photos. Only serial port downloads are supported under Windows XP for the PDC 1100 camera. Follow the instructions below to reinstall the PhotoMAX software and camera drivers using Windows XP's Program Compatibility Wizard. 1. Insert the PhotoMAX CD-ROM in the CD drive. If the program begins installing, press OK to close the "not compatible with Windows NT" error message. 2. Start the Wizard by clicking the Start button and choosing All Programs > Accessories > Program Compatibility Wizard. Follow the on-screen prompts. 3. On the second screen, select I want to use the program in the CD-ROM Drive and click Next. 4. Select Microsoft Windows 98/Windows Me and click Next. NOTE: You may have to scroll down to see this option. 5. Uncheck the following items: * 256 colors * 640 X 480 Screen Resolution * Disable Visual Themes 6. Click Next. 7. Click Next again. The PhotoMAX software will begin installing. Follow the on-screen prompts. 8. Follow on-screen prompts to finish the installation and click Finish. 9. When the Compatibility Wizard asks if the program worked correctly select Yes and click Next. 10. When the program asks if you want to send information to Microsoft, select No and click Next to finish the installation. 11. Shut down and restart the computer. After the restart, you should be able to download photos using Windows XP.
Sep 14, 2005 | Polaroid PhotoMax PDC 1100 Digital Camera
Computer "hangs up" when displaying the Polaroid Album in PhotoMAX
This error or system hang-up is usually caused by: 1. the camera driver software attempting to read a corrupted photo; or 2. there are too many photo thumbnails stored in the PhotoMAX temporary storage area. In either case, the problem can be corrected by manually deleting the Fun! Digital 320 camera thumbnails from the Polaroid Album (using the Windows Explorer or My Computer icons). Follow these steps to delete the Fun! Digital 320 temporary files: Step 1 -- Locate the temporary photo files If you are familiar with Windows Explorer, simply browse directly to: C:\Program Files\Polaroid\PhotoMAX SE\Digital 320 If you are new to browsing the file system, follow these steps: 1. Double-click on the My Computer icon on the desktop. 2. Double-click on the C: drive. 3. Double-click on the Program Files folder. 4. Double-click on the Polaroid folder. 5. Double-click on the PhotoMAX SE folder. 6. Double-click on the Digital 320 folder. Step 2 -- Delete the temporary photo files Inside the Digital 320 folder, you will see many files, most of which will be bitmap image files. All of the bitmap files that start with dsc_ (example: dsc_005.bmp) must be deleted. To delete the files, you can either drag them into the Recycle Bin, or highlight each file by single-clicking on it and pressing the Delete key on the keyboard. To select multiple files at once, hold down the Shift key on the keyboard as you click on them, then press Delete. IMPORTANT: Do not delete the following files from the Digital 320 folder: * 320popup.rtf * DscDrv_Polaroid.dll * Polaroid Album.exe
Sep 14, 2005 | Polaroid PhotoMax PDC 3035 Digital Camera
320 x 240 dpi Photo Transfer Problem
Certain computer hardware and software configurations conflict with PhotoMAX or PhotoImpression software. As a result, you may not be able to transfer 320 x 240 dpi photos from your Polaroid Fun! Flash 640 digital damera. This problem does not occur if you use the camera's default resolution of 640 x 480 dpi.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Can I use the Fun! Flash 640 SE camera with Windows XP?
Yes -- with some minor modifications, you should be able use your Fun! Flash 640 SE camera with a computer running Windows XP.
Polaroid PhotoMax Fun 320 Digital Camera Logo
216 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
