Question about Arris DSR922
Power outages cause receiver to lose unit ID numbers.
How can I reinstate the unit ID numbers that have reverted to all zeroes from two subsequent power outages?
    Problem Solver:
  • 7 Answers
When the backup battery goes dead you loose the ID number.
http://www.pacificsites.com/~alanjudd/922.htm
If you have lost your receiver ID number you will need a new main board.
Check the receiver number in the status screen. If it matches the UA number on the back sticker you are ok, if not the only solution is replacing the main board. ATSelectronics.com still had some boards when I last checked. But when they run out were all screwed.
Motorola didn't make any provisions for renewing the ID number.
That really sucks motorola ;-(
Posted on Jan 29, 2009
I have a dsr 410 receiver,the id looks normal but a guy at skyvision told me the id number was not in they data base & told me the receiver cannot receiver a hit,how can i tell if this id # has a problem
Posted on Aug 05, 2009
My base unit unit keeps flashing 8-88, and the hand sets all say searching
If there is an error code with an E followed by a number or "88" displays/flashes it would be an internal issue in the base unit. Uniden does offer a limited 1 year warranty (Covers Manufacture Defects ONLY, if caused by a power surge or power outage or any other type of damage that is not a Manufacture Defect this is not covered under warranty) off the proof of purchase. The proof of purchase is required for warranty service.
May 10, 2015 | Uniden D1484-4 Dect Cordless Phone With...
I have a Yamaha htr-3065 HDMI receiver that won't turn on after we experienced a power outage. When I plug the unit in I get a buzz sound from transformer but still won't come on. The fuse and power supply...
If you have any electronics experience you should check the diodes or the bridge rectifier in the power circuit. Look for burned components or bulged capacitors.!!!Always unplug the unit and wait a few minutes before attempting any procedure!! I have found that capacitors usually fail due to voltage spikes which can happen when power is reinstated after an outage. Always use surge protectors on electronic devices. They have a component called an MOV that will absorb voltage spikes and save your equipment.
Oct 03, 2014 | Audio Players & Recorders
Reset after power outage
Most programmable thermostats have batteries to keep the program from being lost in a power outage. If you thermostat has dead batteries or no batteries a power outage will cause the thermostat to revert to a default setting and it will have to be reprogrammed. Hope this helps.
Dec 22, 2013 | Honeywell Heating & Cooling
AVR-2803/983: Had recent 24hr Power Outage. When power restored, I receive no video/sound from TV thru COMCAST HD box, no video from CD but do get sound, lost partial use of Zone 2. Zone 2 works if I...
Extended power loss might lose memorized settings. Pretend the unit is brand new and verify all of them. No video from CD??? Really? Good luck with that.
Jul 16, 2011 | Denon AVR-2803 Receiver
I lose wireless network ID and WEP when power is momentarliy removed from the router
if its a big problem like power outages id get a usp battery power backup and connect it to the router so you wont lose the info
Sep 26, 2009 | Linksys WCG200 Wireless Router
DSR 922- to begin with it wouldn't shut off, no function will work with the remote, unplugged it and replugged it and now there is nothing but the inspirational channel on G3 217. H20
IF the receiver lost its sat settings you had, you best check the internal battery. the lithium battery should be 3.70 volts...if its dead you need to replace it, without interupting the power source...this will also cause you to lose your unit ID number. then you won't be able to subcribe to programming...the 922 can be repaired if the battery dies.
Jul 09, 2009 | Arris DSR922
I have a JBL MR-17.2 Sirius Ready stereo
To get your Sirius ID number from you MR-17 JBL stereo, select the Mode button until it displays "Sirius". Then push and hold the Mode button for a couple seconds and it will chirp and display 3 blank spaces. Enter three zeros, "000" in these 3 spaces. The Zero is the loud button labeled "LD". When you do that, it will display your Sirius ID number. :)
May 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Lost power for one second and now cannot get my caller ID to work
unplug the telephone cable from the back of the receiver and plug it a basic telephone to check if there is a dial tone. if there is a dial tone restart the receiver without the the telephone line plugged in. after it loads and u have a picture, plug in the telephone line. call the home to check. if its not working the modem in the receiver has gone bad.
Oct 20, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Onkyo Forgets it's input settings during power outages
yes there is ,,, it is located on the same board that has 3 fuses on it, you will have to unplug the unit before disassembly, and remove the top cove and bottow covers,,,, you will have to de-solder a small battery pack surrounded by either blue or yellow heat shrink,,, please not the polarity before removal, as putting it in wrong will cause a non- memory retaining situation to continue...I hope this helps
Jul 07, 2007 | Onkyo TX-DS787 Receiver
Power Outage?
johnny try to connect the fridge using a stabliser to the wall plug and make the control to the min coll and check if it is ok then the problem is of the connecting load to the wall plug
Jul 03, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Televison & Video Logo
697 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
