Samsung LCD 40 Television screen goes green in place of black
    Genius:
  • Televison & ... Master
  • 1,689 Answers
This could be a fault in the matrix decoder for the screen drive. It may also be a defect in the screen substrate itself.
If you take the set to the Samsung service rep, they will try the various boards to determine the failed board. They they can swap the board to fix the set. Then they will do the configurations as necessary to make sure it is working to specs.
Jerry G.
Posted on Sep 05, 2008
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Black screen, but sound
maybe it is the panel eeprom,if the panel inverter is good which should be treated with experts
Jan 14, 2013 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have a 40' lcd samsung and have got 3 colored lines, a red, blue and green, about 3' in from the left hand side, anyone else had this problem or know how to fix please?
COULD BE A LOOSE LVDS CABLE, IF NOT THEN MAYBE A TAB BONDING ISSUE, YOU WOULD HAVE TO REPLACE THE ENTIRE SCREEN, GIVE IT A SHOCK TEST, GENTLY SLAP THE BACK ON THE TOP MIDDLE AND SEE IF IT GOES AWAY OR CHANGES, IF THE LVDS CABLE IS LOOSE THEN IT NEEDS TO BE RESEATED AND COULD FIX IT, IF NOT THE SCREEN IS ABOUT 80% COST OF WHAT TH TV IS WORTH
Dec 30, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Dec 26, 2009 | Proscan PS50700 50" Rear Projection...
Samsung 40 inch lcd screen goes black just got sound
most likely the main board is defective but it could also be the lcd panel itself or the lvds cable.probably will need a service call to determine problem.
Oct 28, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung LCD Screen powers up for 1 minute then goes black.
Most likley there are some bad capacitors that need to be replaced in the power supply, in particular the ones that are "10 volt" types. As a tech...I LOVE to see these sets and or//power supply boards come in as it is "easy and quick money for me" and a quick and lasting repair for the customer. A decent shop should be able to repair your PS board for under 350, in home service.
Oct 09, 2009 | Samsung LN-T4053H 40 in. LCD Television
Samsung LNS 4051D color problems
1.T-con board or related cables problem -- 60%
2.replace Main Board -- 40%
Jan 25, 2009 | Samsung LN-S4051D 40 in. LCD Television
Green & red lines on screen
This is likely a bad logic board but most of the time it indicates a bad LCD panel
Jun 12, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung 40" 1080P power flux
Try to replace the Power Supply board first.
Feb 01, 2008 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
