Question about Belkin Computers & Internet
Router "wireless G" will not
Router "wireless G" will not stay connected. Looses connection after 7 seconds. If I connect directly to computer and don't use router, no problem. I have unplugged and disconnected everything and reconnected to instructions and still no improvement. I have re-run the install Cd and no luck there either. Direct from DSL to computer works great, thru router, constant disconnect after 7 seconds. Purchased router 12-13-07 Have paperwork and box. Fixable? Warranteed? Hash and needs replace?
  • Matthew Rodela
    Matthew Rodela May 11, 2010
    Find the model number of the router and check belkin's website to see if they have any software updates or patches that may fix your problem. What version of Windows are you using?
I called tech support# received with router and 5 minutes later ...FIXED
Needed config update and support was great. Did NOT need replace
Posted on Sep 11, 2008
    Scholar:
  • 65 Answers
I had the same problem with a router of mine. I had it replaced and the new one works great.
Posted on Sep 05, 2008
My Dir 615 router always looses internet connection to my wired computer
Try to upgrade the routers firmware.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
Jul 19, 2013 | D-Link Computers & Internet
Blinking lights
when the router looses connection, it is best to just leave it as it tries to reconnect automatically
the blinking lights is the communication process and when connection is made for each section the light stays full on
there should be a on/off button that you just press to restart the searching process or a reset button under a small hole that you use a paper clip to gently press to reset
remember that it is not always the router that looses the connection but the server that it is connecting to
Jul 10, 2017 | Cisco -Valet Wireless Router
New laptop won't stay connected wirelessly on start up
Connection problems can only be caused by two things.
A bad or week signal from your router, try moving it or moving the computer closer to it.
A faulty receiver in the laptop itself. This happens. Try it in Starbucks or MacDonalds to check it.
Nov 26, 2017 | Samsung np700z5b-s01ub 15.6" series 7...
Setup didn't work, "details" section on network
Win7 will connect without any problems, but win vista will not get connected to the network...
You can update the drivers for wireless adapter in vista laptop, it will get connected...
If it still not getting connected then change the security settings on your router to 64bit WEP... (Initially it will be in WPA)
disabled the WPS (wifi protected setup) in the router...
change the ssid in the router...
Now try to connect to the new wireless network...It will work perfectly....
click here to configure the wireless part of your belkin router...
Any issues call 18002235546 ( 24/7 )
Feb 06, 2011 | Belkin Play N600 Wireless Dual Band Router...
Everything is connected my laptop was able to find the name of my wireless but was not able to connect. I'm using windows 7 on the laptop. Any idea of what i should do to fix the problem. Everything was...
Hi. First issue why your laptop cant connect to your router is regarding witht the password. Make sure that you are typing in the correct password of your router. Check the type of authentication used e.g WPA, WEP etc. Second issue, is this the first time you used windows 7 OS in connecting to your router. There are issues in linkys routers that is not compatible with windows 7 and you need firmware upgrade for your router. You can also try to test the connectivity using a wired conncetion (LAN cable) conncet directly to your router nd se if you were able to get an internet concetion using a wired connection.
Have a good one!
Jul 28, 2010 | Linksys Wireless-G WRT54GS Router...
I changed the username and password on my Netgear router so make it more secure. Now, I can't get an internet connection when i have my ethernet cable plugged in to my router, only when I have it directly...
  1. Set up and plug in the Netgear router and wait a few seconds for it to boot up. Since the router is essentially a mini-computer, it won't work instantly when it's turned on. While it's booting, the power light should flash. When it's finished booting, the power light should stay solid.
  2. Step 5 Connect a computer to the router, either with a wireless or a wired connection. Reboot the computer to ensure it gets a new IP address from the router via Dynamic Host Configuration Protocol (DHCP).
  3. Step 6 Open the web interface by entering "http://192.168.1.1/" into the address bar of your web browser. If a login screen is presented, use "admin" as the username and either "1234" or "password" as the password.
  4. Step 7 Connect to the Internet, if necessary. Plug your cable modem or DSL modem into the router's WAN port in the back and run the Internet Connection Setup Wizard from the web interface.
  5. Step 8 Follow the directions and provide authentication information.
  6. Step 9 Connect more clients. At this point, clients should be able to connect and access the Internet.
Apr 29, 2010 | NetGear WGT624 Wireless Router
HN9000 DSL and RangeMax Wireless not connecting wireless laptop
uninstall then reinstall wireless card drivers then reconnect.
Jul 26, 2009 | NetGear MR814 Wireless Router
I have a Buffalo g54 Wireless router, it keeps loosing wireless connection. Works fine when directly next to the router but when you move away it looses connection.
Buffalo wireless routers are **** and never work right, i suggest you go out and buy either Netgear or Lynksis routers as these are the best, unfortunealeley there is no fix for this a the range of the routers are limited, stick to brand name equipment
kind regards and please don't forget to rate us
Dec 08, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
