Question about Polaroid PhotoMax Fun 320 Digital Camera
My Fun! Digital 320 camera does not power on.
Check to see that the On/Off switch is in the On position. Check to see that the green power light on the back of the camera is lit. If it is not lit, make sure that the battery is loaded properly. If necessary, insert a fresh battery and try again.
  • 513 Answers
Are you asking or answering? ;]
Posted on Mar 02, 2006
Bunn not heating water
Don't know the model but here are things to check prior to calling your vendor for service:
* Plugged in? No lights? Check if GFRI outlet is tripped out.
* Is it turned on and ready light lit? Some (CWTF's etc.) have a green or read ready lamp that lights up when the brewer is hot and ready to brew.
* No Ready light after 15-20 mins of being plugged in? Check the back of unit for a toggle switch (or rocker switch). Check if it's on. Some units may say "Vacation". It should be on normal or brew.
* Brewing works but not hot. Was the ready light on when you started the brew? You have to wait till it's lit. Still not hot? Then call for service. The heater, High limit, Thermal fuse,Thermostat needs to be checked.
* If this is a new unit then be sure to turn on the thermostat as it comes from the MFR in the off position.
* Final, Call your vendor to be safe.
Aloha, ukeboy57
Jun 12, 2017 | Bunn Coffee Makers & Espresso Machines
Green light on unit not lit, no test startups as
Check the battery condition, and charger. Check also the fuses in the transfer switch (note they are line voltage so maybe call an electrician)
Oct 26, 2013 | Generac Honeywell 20KW Standby Generator
My Panasonic Lumix DMC FS3 is not powering on fully.... When I switch the camera to the on position the green light blinks on and then off and the lens opens but the screen doesnt seem to power on. When I...
see if the memory card cover had been open in that moment .However if the problem persist the camera must go to the repair shop. The syscom and associates circuit has faulty .
God bless you
Oct 04, 2012 | Cameras
Nikon D90 flashing green light runs down battery even in power off mode.
Possible short to the top cover circuit around and including the on/off switch - spillage, wear of switch.
Apr 06, 2012 | Nikon D90 Digital Camera with 18-105mm...
The vacuum won't turn on. It"s an upright,and the power light on the on/off switch is lit, but no power to the unit below.
Check that you have power at the motor with a tester 0-200v .If you have it could be brushes or u/s motor.If not check power out from the switch ,if ok you you need to replace cables.
Please leave a positive feed back for me if this helps and get back to me if you need more help
Thankyou
Aug 09, 2009 | Oreck XL2200 Bagged Upright Vacuum
Computer will not turn on
May sound strange, but is the power supply switch in the correct position?
If the button is pressed, makes your continuity test, and not even the fans come on, check that the switch jumper has not come loose from the motherboard, and finally, if the motherboard is plugged in and no fan comes on when you push the power button, there may be chipset damage from an electrical surge or overheating.
In this case, a new mobo is your only option.
Jan 20, 2009 | Dell Dimension 4600 PC Desktop
My Fun! Flash 640 does not power on.
Check to see that the On/Off switch is in the On position. Check to see that the green power light on the back of the camera is lit. If it is not lit, make sure that the batteries are loaded properly. If necessary, insert fresh batteries and try again.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
My Fun! Flash 640 does not power on. What's wrong?
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Polaroid PhotoMax Fun 320 Digital Camera Logo
51 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
