Question about Kenmore 44932 Front Load Washer
F05 Error Code on Kenmore Elite HE3T Washer Model 11044932200
I followed the steps on your site. The 3 test results.
1) NTC tested 9.7
2) Heating Element tested at 0
3) Heating Element Solenoid (The connector 2nd from right on the CCU - port is labeled HE2 on CCU) tested at 0.
Question: Does this mean that both the Heating Element and the CCU need replacing???
Thanks
Jim
  • 1 more comment
  • fhsystems Sep 13, 2008
    Yes, the washer was powered down.
    Yes the connector was solidly affixed to the NTC. No corrosion either. The NTC gave good readings.
    All wires were disconnected from the heating element; including the NTC and ground wire. Zero reading.
    I tried a resistance check from the CCU connector back to the NTC - it
    came back zero. It was difficult trying to get the testers contacts on
    the connectors contacts though. I checked the wire as best as I
    could. The wire is zip-tied and in a raceway so its difficult to see
    if there is a flaw in the wire.
    Also, since the previous heating element came back with a zero reading
    I recently purchased a new heating element from Sear Parts online. The
    machine will now operate in both cold and warm cycles, whereas with the
    previous heating element the machine would run on cold cycles only.
    The machine does not, however, run on hot cycles - still the F05 error
    after a few minutes.
    Any ideas?
    Thanks in advance
    Jim
  • fhsystems Sep 14, 2008
    Thanks for the quick response.
    Yes, when the machine F05's during a hot wash the water is hot.
    I did the solenoid test. 822 on both.
    I rechecked the heating element. Turns out I got a zero reading on the new one too. When my voltmeter is set to 20K Ohms it gives me the proper reading for the NTC but not the heating element. After some trial and error I noticed that I need to adjust the meter setting to a symbol that has a right-facing arrow pointed toward a plus sign. (Just FYI, if that matters. The tester is a Greenlee DM-50).
    I checked both the new and old Heating Elements and NTC's.
    The old one reads 16 and 10 respectively.
    The new one reads 15 and 11 respectively.
    The house is about 84 degrees during the test.
    Knowing this I'm wondering, in all my noviceness, if it's either the CCU or the wiring.
    Any ideas?
    Thanks
    Jim
  • fhsystems Sep 15, 2008
    Found it!
    I found it hard to fathom that it could be the wire - seeing as how it is so secured via zip-ties and protective raceways. But I noticed that one of the NTC's wires was slacked and the other was pulled tight. I laid on the floor and looked up inside the machine. Almost directly behind the door handle was a screw on the drum which somehow had one of the NTC wires behind it. When I dislodged it I could feel the PVC jacket was worn, wire exposed, and the wire feels pretty much broken within it. So I think it's safe to assume that's the culprit. I'll get a coupler and do a little cut and splice.
    I wanted to let you know the outcome and thank you guys for your help.
    Jim
  • 5,911 Answers
First of all, make sure you unplug the washer before making any measures, and make sure you unplug any connectors from the CCU, so you aren't reading parallel paths. Isolate the components you wish to test from the CCU or you may get inaccurate readings.
The reading across the heating element terminal should read 15 ohms. Make sure you aren't grounding your probe against the case, or you will get improper readings.
The NTC will read approximately what you have at room temperature. Was the connector plugged in before you began troubleshooting? A common problem is the connector falling off and generating the error code.
As far as the connector plug on the CCU is concerned, plug layouts can differ between models. Make sure you have the correct connector plug to the NTC. You may have to hand over hand it to find it. Unplug the connector at the CCU and leave it plugged in to the NTC. Perform a resistance check across the PLUG terminals. You should get the same readings as you mentioned before if the plug and wires are good. This not checks the resistance of the NTC, but also proves continuity of the wires.
Doublecheck your readings and let me know what you have. I would like to rule out a CCU problem. It is not common for this error code. I hope this helps you.
Posted on Sep 05, 2008
  • Jeff Rockwell
    Jeff Rockwell Sep 14, 2008
    Okay...do you have any water coming into the washer when a HOT cycle is selected? There is a water inlet valve that has two solenoids that control water flow when the washer fills. One solenoid controls COLD water flow, while the other controls HOT water flow. On a warm water cycle, a combination of botyh solenoids are used to make warm water. You may have a water inlet valve problem where the hot solenoid no longer works. That is why it may appear to be working on COLD and WARM cycles, because the cold water solenoid is still allowing water to flow. Even though the washer has a separate heating element, the element is used to super heat the water for sanitary cycles and cleaner results for removing stains.
    Remove the top panel of the washer by removing the three screws that hold the panel in place in the rear of the washer. Once the screws are removed, the panel will slide back, then off. The fill valve is located in the left rear of the washer (as viewed from the front). A resistance reading across the solenoids should be about 800 ohms.
    Let me know if this helps you.
  • Jeff Rockwell
    You're one step ahead of me...the wiring and/or CCU are the only logical choices left if you've confirmed everything else. The water inlet valve solenoids appear to be good and water is flowing. That was a long shot anyway...
    The heating element solenoid is connector 9 on the CCU. This is the 2nd connector from the right on the front of the CCU. The way you can confirm the wiring is to leave the connections plugged in at the heating element, remove the connnector from the CCU, and take a resistance reading across the pins of the connector plug. If you read a resistance of approximately 15 ohms, this confirms the wiring is good to the heating element. If you've already confirmed this, the only thing left is the CCU itself.
    Sorry to keep having you chase your tail on this matter. I admire your diligence, though. I hope this helps confirm something for you.
    PS The other scale you are talking about on your multimeter is a continuity checker. This is great for checking wire runs and the biasing of certain semiconductors, but it can give misleading readings when a resistance needs to be confirmed.
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps (remember to rate and lave a testimonila about this free answer).
Sep 30, 2011 | Washing Machines
Tip
F05 Error Code
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the “F05” Error Code.
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope this information if found to be helpful.
on Dec 09, 2009 | Washing Machines
Tip
F05 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washing Machines
I hope this information if found to be helpful. If you have questions, or need assistance locating parts, please click on the following link and use the “ASK ME” feature for a quicker response.
http://www.fixya.com/users/jsrock516
on May 28, 2008 | Kenmore Elite 45986 Front Load Washer
F05 error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
What does the error code F05 mean on the he 4t front-loading washer?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
May 13, 2010 | Kenmore Elite 45986 Front Load Washer
F05 error
"F5" is a Temperature sensor (NTC) error. The following link explains:
http://www.fixya.com/support/r3608669-f05_error_code
The NTC, or temperature sensor, is located under the bottom front of the wash tub. It is a small square black plug between the heating element terminals. In many cases the connector plug comes loose and simply needs to be reconnected.
If the NTC is defective, a replacement can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The average cost is about $10. You can view an image of the part here:
http://www.appliancepartspros.com/part_details.aspx?part_id=3128829&pn_=8181705
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Mar 23, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore elite he3t washer. It flashes f5 at the beginning of a cycle
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Feb 04, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F05 on screen
Hi. This is a water temperature sensor issue.
Replace any parts that is malfunctioning or defective.
Oct 04, 2009 | Washing Machines
What is the F05 error code for on my Kenmore elite he 4t washer
Jun 16, 2009 | Kenmore 44932 Front Load Washer
Kenmore Elite front loading washer HE 3t
"F05" is a water temperature sensor error. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Make sure the connector is firmly attached to the NTC sensor upon your intial visual inspection. In many cases, the connector comes loose and causes the error. Make sure you follow the advice in the link provided for resistance readings. I hope you find this information helpful. Let me know if you still require assistance.
Sep 30, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 44932 Front Load Washer Logo
925 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
