Question about Uniden BC80XLT Handheld Scanner
Just bought this scanner used and having problems with Banks 3 and 4
I just bought this scanner through craigslist.com and I have already programmed the channels that I want but can't seem to get Banks 3 and 4 to scan. When the scanner is in scan it will not go through these two banks. I don't know if this is something normal that it does. I have checked the manual and I made sure that these banks were not on lockout. Please help me out!!!!!
  • 120 Answers
While the scanner is scanning press buttons 3 and 4 and they should start scanning too, if they dont then go to the first channel in bank 3 manually and press LO to unlock it, then hit manual again to go to the next channel and press LO again to unlock it( all of the channels in the bank are probably either locked out or empty(nothing programmed into them)
Posted on Jan 02, 2009
I Havel a pro-95 scanner and I have frequencies programmed into banks 1 thru 6 and the scanner isn't scanning banks 2 thru 6
Make sure the banks are enabled and the frequencies in the banks aren't locked out. If you are scanning trunked systems make sure the control channels are set up properly.
Keep in mind you cannot scan digital systems with this scanner, only analog systems and frequencies.
Pro 95 The RadioReference Wiki
Mar 07, 2017 | Radio Communications
Scanner stuck on one channel and won't allow me to enter new freq
Push the "L/O" lockout button and it will lockout that channel.
When you press "Scan" you have to have at least one of the banks scanning, so press 1, 2, 3,....9, 0 whatever bank you have channels programmed in order to automatically scan. You should be able to press "Manual" to see each channel individually.
May 07, 2014 | Uniden Bearcat BC 220XLT Radio Scanner
BC72XLT scanner does not stop on some programmed channels while scanning. My other scanner will read the transmission. The numbers indicating banks 1 and 3 aare not visable during scan, are they locked...
what it is because that your other banks are locked out and thats why it by passes your frequencies...unlock your banks and it will stop on the transmissions...
Apr 01, 2011 | Uniden BC72XLT Handheld Scanner
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Mar 29, 2011 | Uniden BC370CRS Base Scanner
Bc898t all 500 channels are locked out. How to unlock all of them
Mar 29, 2011 | Uniden BC898T Base Scanner
WHAT CHANNELS CAN YOU USE IF YOU HAVE A POLICE SCANNER 53218
Your PRO-96 has 10 banks of 50 channels, giving you access to 500 channels for conventional systems. It also has 11 banks of 500 channels, giving you access to 5500 users on trunked systems. Detailed instructions for programming the scanner are contained in the factory operating instructions, which you can download and print at no cost here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
For a comprehensive database of active frequencies and trunking systems in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Aug 04, 2010 | Radio Shack Pro-96 Scanner
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
I have a realistic pro-2021 scanner and dont know how to operate it other than turning it on or off can you help ??
Programming Frequencies
1. Select the desired channel.
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency.
4. Press [ENTER].
Selecting the Channel
Step 1:
1. Press [MANUAL]. Continue pressing until the display shows
Channel 20. Press [PROGRAM].
2. Press [2][0][MANUAL]. Press [PROGRAM]. (or press [PROGRAM],
press [2][0], press [PROGRAM]).
Step 2:
Press the keys (example 162.55)
Step 3:
Press [ENTER]. To program the next frequency, move to another channel in
this way. Press [PROGRAM] to advance to the next channel. Repeat the
same steps to add more frequencies.
SKIPPING BANKS
1. Turn the power on.
2. Press the number key that corresponds to the bank to be skipped.
3. The corresponding bank number indicator disappears from the display
and the entire bank is skipped.
NOTE: To restore the banks, press the number key again.
SEARCHING WITH YOUR PRO-2021
To search for transmission, press [PROGRAM], enter limits of frequency
range, and press [up arrow] or [down arrow] to activate "search."
1. Press [PROGRAM].
2. Press [LIMIT].
3. Enter the lower limit of frequency range to be searched.
4. Press [ENTER].
5. Press [LIMIT].
6. Enter the upper limit of frequency range to be searched.
7. Press [ENTER].
Activate "search" by pressing [up arrow] or [down arrow]. [Down arrow]
starts search from the highest frequency and goes down. [Up arrow] moves
in the opposite direction.
Press [SPEED] to accelerate or to slow down the search.
Jan 07, 2010 | Radio Shack Pro-2096 Base Scanner
Pro 82 Scanner from Radio Shack problem!!
While its in scan mode press the # of the channel to select.. you will see the bar go under the # Then it will scan the channel
Jun 04, 2009 | Radio Shack Pro-82 Scanner
Uniden BC80XLT Handheld Scanner Logo
200 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
