Hello, I have Hyundai Ductless Air Conditioner unit (model WSH-302BA) which has recently started turning on by itself at various times and blowing very cold air. When this happens all the lights on the wall unit flash and there is no way to turn it off other than via the power. Any idea what the problem might be? Rgds Linda
  • lindasing Sep 05, 2008
    What a great service! The response was not only quick but also very informative.
  • 421 Answers
Sounds like you are picking up interference from a neighbors or your own home try having the remote chanel changed otherwise the power button may have a short, either way you need to call for service good luck and please rate -jeff
Posted on Sep 05, 2008
  • jeff r
    jeff r Sep 05, 2008
    try removing the batteries from the remote controller also and see if the problem persists it would not be your timer as that has logic built into the remote good luck please rate -jeff
  • jeff r
    jeff r Sep 05, 2008
    do you still have a manufactures warrenty on the unit? if so this should be covered good luck please rate -jeff
    President:
  • 1,952 Answers
Off the swicth of light u get cold air bec light hi
eat absurb the cool air
  • mohammed marika thambi
    mohammed marika thambi Sep 05, 2008
    off the swicth of light u get cold air bec light high
    heat absurb the cool air
    Genius:
  • 1,269 Answers
The timer's circuit is malfunctioning. Replacing it will fix the issue. Meanwhile Try to unplug the power of the unit for about 3-5 hours then check if it fixes it. Double check the air filter if it's frosting.
Outside unit turns on and runs for a long time by itself then shuts off. Does this all day an night long. Notice this after a circuit breaker tripped. Not breaker to unit though. Other parts of house.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other Air Conditioning Repair help. Check us out online.
Jul 25, 2016 | Celiera Celi 24000 BTU Ductless Mini Split...
How can I fix
Hello, try to clean and dry the electronic board, sometimes the humidity make shortcircuits between logic gates.
Oct 24, 2014 | Senville 18000 BTU Ductless Air...
HOW DO I CHECK AND CORRECT THE FREON LEVEL FOR MY SANYO KS1271 A/C; WHICH IS NOT BLOWING COLD AIR?
Hire a tech it will be cheaper and safer. You may have a capacitor that is bad and not starting the compressor.
Aug 22, 2014 | Sanyo KS1271 11,900 BTU Ductless...
My hitachi ductless split room air conditioner with heat pump is not heating my room , i have cleaned out the filters and unplugged the unit for 10 min and plugged in back in and it only blows cool air , i...
dear sir
please reset you air conditioner by it,s remote to heat mode and check thermostat setting maybe it has been turn off after remove air conditioner,s electric supply plug from electric source . i hope after reset it will be able to work again.
hope answer the question
thank you
please vote!
Oct 03, 2010 | Hitachi RAS-09UH Air Conditioner
I have an old Kenmore 25,000 BTU Air Conditioner (Model number 253.7792580). Recently it started blowing air that is not really cool, it's actually room temp. It makes a slightly different sound when it is...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Kenmore Heating & Cooling
I have a Samsung Ductless Air Conditioner. It wil...
i think there is a short circuit in the fan or compressor even in the board.loop check it & say how many amper is there?
May 21, 2010 | Samsung AS18A6RB Air Conditioner
One of my ductless a/c units is not blowing cold
Check to see if all of the outside condensing units are running. Identify the one that is part of the "problem" system. Is it running? What is different about that one than the others? Let us know and we will dig deeper into helping you troubleshoot.
If it is not running, check for any tripped circuit breakers or blown fuses to the outdoor unit.
Let us know.
I hope you find this information to be very helpful to you as a jumping off point, moving forward.
Please leave a rating. :-)
May 14, 2010 | LG LA185HV Split System Air Conditioner
Heating & Cooling Logo
159 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
