Question about Polaroid PhotoMax Fun Flash 640 Digital Camera
Two green LEDs are blinking?
What does it mean when the two green LEDs on the Fun! Flash digital camera are blinking?
    Master:
  • 450 Answers
The two green LEDs on the back of the camera indicate a number of camera conditions. If they are both blinking, the camera's memory is full and the camera will not take any more pictures.
Posted on Sep 21, 2005
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Can I use the Fun! Flash 640 with a USB port?
A 9-pin serial connection must be available on your computer to connect a PhotoMAX Fun! Flash 640 digital camera. This camera model does not have a USB driver, so a USB-to-serial adapter will not function properly.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Error code messages in the status panel of the Fun! Digital 320 camera.
The following is a listing of the error codes you might see on the status panel of the PhotoMAX Fun! Digital 320 camera: 1.FL - Photo memory is full. You cannot take more photos. Download and then erase the photos in your camera. 2.FE - Flash memory error. A camera hardware error occurred. This can happen when the power is shut off before a photo is completely stored in the camera. Do not shut off the power until the green light comes back on steady after you take a photo. 3.bE - Hardware problem. Turn the power switch on and off and see if the error message disappears. If the error message persists, the camera may need to be replaced. 4.Lo - Battery low. Replace the camera battery as soon as possible. If you continue to use the camera, picture quality will be poor. 5.LL - Low light condition. The camera does not have enough light to take a good photo. Improve the subject lighting if possible. Example: When taking indoor photos, add additional room lighting.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Batteries?
When the camera detects low battery power, the LCD shuts off and the green power status light blinks once a second.
Can I use my Fun! Flash 640 digital camera with other software applications?
Yes, you can use your Polaroid Fun! Flash digital camera with many popular image-editing software applications. The Fun! Flash is TWAIN-compliant and comes with its own image acquisition software, which is automatically installed when you install PhotoMAX. Just open your image-editing software and select Polaroid Fun! Flash as your acquisition source.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Can I use a Polaroid digital camera as a web camera?
None of the Polaroid digital cameras listed below can be used as a "web cam." All of these models are designed for taking still images only. DMC/DMC 1e DMC2 Fun! Digital 320 Fun! 620 Fun! Flash 640 Fun! Flash 640 SE Fun! Flash 820 MP3 Digital Camera Olympus C-211Z PDC 300 PDC 640 PDC 640CF PDC 640M PDC 640 Plus PDC 700 PDC 800 PDC 1100 PDC 1300 PDC 1320 PDC 2000/3000 PDC 2300Z
Sep 14, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
My Fun! Flash 640 does not power on.
Check to see that the On/Off switch is in the On position. Check to see that the green power light on the back of the camera is lit. If it is not lit, make sure that the batteries are loaded properly. If necessary, insert fresh batteries and try again.
My Fun! Flash 640 does not power on. What's wrong?
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Polaroid PhotoMax Fun Flash 640 Digital Camera Logo
69 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
