Question about Polaroid PhotoMax PDC 640 Digital Camera
USB port with the PDC 640 camera?
Can I use a USB port with the PDC 640 camera?
    Master:
  • 450 Answers
The Polaroid PDC 640 digital camera connects to an available 9-pin serial port only -- it does not support the use of a USB/serial converter. However, you can use a SmartMedia Card Reader with the camera's reremovable memory to download the images via the USB port to your computer.
Posted on Sep 21, 2005
Can I use the Fun! Flash 640 with a USB port?
A 9-pin serial connection must be available on your computer to connect a PhotoMAX Fun! Flash 640 digital camera. This camera model does not have a USB driver, so a USB-to-serial adapter will not function properly.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
My PDC 640 digital camera's memory locks up (when I'm using a memory card). What should I do?
The camera memory may "lock" as it reaches its limit. With the camera disconnected from the PC, and on battery power, turn off the camera by closing the lens cover. Remove and reinsert the memory card. Now turn on the camera -- it should power on properly.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
My new PDC 640 camera is not turning on.
This problem may be due to one of the following: * The lens cover is not open. Slide the lens cover to the right. * The batteries are not inserted properly. Remove the batteries and check the placement of the (+) positive and (-) negative ends. Then reinsert them, making sure they're securely in place. * The batteries are dead. Put in fresh replacements. Power issues may also be the result of using the wrong AC adapter. Use only the recommended AC adapter for the 640.
How do I the delete images so I can re-use the memory card?
To delete photos from the SmartMedia memory card in your camera, you must first download them to your computer. Follow this procedure to transfer your photos from the camera to your computer: 1. Make sure that your PDC 640 is connected to your computer and both are turned on. The "PC" icon should appear on the status panel on the top of the camera. 2. Open the PhotoMAX application on your PC. 3. Click Get Photo. Note: If you are using PhotoMAX Pro to transfer pictures, you need to select PDC 640 Camera from the Select Source dialog box (select File > Acquire > Select Source), and then select File > Acquire. 4. Click Album or flashPath. 5. Select the album in which you want to save your images, or click New Album to create a new album. 6. Click Camera or Scanner. 7. Select PDC 640 from the Sources list on the Select Source window, and then click Select. The PDC 640 Twain Driver window opens. 8. Click Get All to transfer all the images in the camera memory to your computer, or select the images you want to transfer to your computer and click Get Selected. The images are transferred to the selected album, which is located in the PhotoMAX Albums folder. The PDC 640 Twain Driver window closes. 9. To edit a picture, double-click the image in the album that you want. The image appears in the image tray.
My system locks up when I attempt to download images from my PDC 640 camera.
While it appears that the system is locking up, the actual problem is that a message prompt in the PhotoMAX 2.0 software is hiding beneath other open windows and needs to be answered before proceeding. In this instance, the PDC 640 TWAIN Driver window has been preset to always be the "top" window, obscuring any other windows that may be open behind it. The PhotoMAX 2.0 window must be "active" (or "brought to the top") to answer any message prompts. Once the message prompt is answered, you will be able to download images. To deactivate the PDC 640 TWAIN Driver window's "Always on Top" preset: 1. Launch the PhotoMAX application. 2. Select Get Photo. 3. Select Camera or Scanner. The Acquire From window appears. 4. Select Twain device and click OK. The Select Source window appears. 5. Highlight PDC 640 and click Select. The album window appears next, followed by the PDC 640 TWAIN Driver window. 6. Right-click on the PDC 640 TWAIN Driver window and deselect (i.e. uncheck) "Always on Top". To move the PhotoMAX 2.0 window forward: 1. Launch the PhotoMAX application. 2. Click on Get Photo. 3. Click on From Album. 4. When the album opens, answer YES to the question "The contents of this album have been changed. Do you want to save the changes?". 5. Click on the Acquire icon at the top of the album window to select the PDC 640 camera and download the thumbnails from the camera. Your system will no longer appear to lock up.
Sep 14, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Can I use a Polaroid digital camera as a web camera?
None of the Polaroid digital cameras listed below can be used as a "web cam." All of these models are designed for taking still images only. DMC/DMC 1e DMC2 Fun! Digital 320 Fun! 620 Fun! Flash 640 Fun! Flash 640 SE Fun! Flash 820 MP3 Digital Camera Olympus C-211Z PDC 300 PDC 640 PDC 640CF PDC 640M PDC 640 Plus PDC 700 PDC 800 PDC 1100 PDC 1300 PDC 1320 PDC 2000/3000 PDC 2300Z
Is it possible to install only the TWAIN driver for my PDC 640 camera?
Yes, you may install the PDC 640 camera TWAIN driver only. The PDC 640 TWAIN driver can be used with most TWAIN compliant image editing software. The most current driver is available for download on our website and is compatible with Windows 95, 98, Me, 2000 and XP (there is no compatibility with Windows NT at this time).
What accessories are available for the PDC 640 and what are their part numbers?
The following accessories for the PhotoMAX PDC 640 camera are available for purchase by contacting Polaroid's Parts Department: Serial cable part # 118082 Video cable part # 109404A AC adapter part # 118079 Camera case part # 100-806003-0 Hand strap part # 1BM857A PhotoMAX software version 2.02 part # 101815B
Can I use the PDC 700 camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will no longer be able to use a USB port to download your photos. Only serial port downloads are supported under Windows XP for the PDC 700 camera.
Sep 14, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Can I use the PDC 640 camera with Windows XP?
Yes -- with some minor modifications, you should be able use your PDC 640 camera with a computer running Windows XP.
Polaroid PhotoMax PDC 640 Digital Camera Logo
133 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
