Question about Maytag MGR5751AD Gas Kitchen Range
Oven not working
Hi. All of the sudden my oven will not heat. The broiler and stove top work fine but when I set the temperature for the oven it never heats up?? Can you help?
  • 2 more comments
  • sammie_veach Sep 17, 2008
    My stove top works fine, but when I turn the oven on there is a red glow and it smells like propane, but the oven never gets hot! We just had our propane pressure looked at and a new regulator valve installed on our propane tank. Any suggestions?
  • notcooking Jan 04, 2009
    Maytag MRG57650DW is not heating up when we turn the oven on. The stovetop works, there is no error code anywhere, but the oven does not heat. We turn it on and wait and nothing happens - usually you can hear the gas ignite but we are not hearing this and the temp never rises. This is two years old.
  • thundr Feb 04, 2009
    I had a repair man tell me it was some board that cost 6 to 700 dollars. Igniter works fine. It comes on, but the gas is too low to heat the oven. broiler and top works fine. I am getting another look, but wanted an opionion on the board???
  • FRANK COOPER Feb 09, 2009
    I can see a bright orange glow from what appears to be the igniter. And I do eventually hear the gas turning on. But it seems to take awhile before that happens. It sometimes takes nearly an hour before the oven reaches the temperature. After the temperature is reached it doesn't reflect the temperature from a secondary oven thermometer that we have set inside to verify it. Any help would be appreciated.
    Novelist:
  • 166 Answers
Peace,
ngafm here at your service,
If its gas then the igniter may be defective. If it's electric your looking at the thermostat.
How old is the range?
it's a service situation
Bless you,
ngafm
Please give me a good rating in at this site before you sign off!
Thank You
Posted on Sep 05, 2008
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven/Broiler doesn't work. Stove top works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 03, 2010 | Tappan TGFS26C Gas Kitchen Range
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Fridgidaire oven will not heat up.
It can be 1 of 3 things the temperature control could be defective, you could have a burnt wire or the bottom ring of the stove cou ld be burnt. If you have a volt ohm meter you could check the bottom ring for continuaty, visiualy inspect the wirring for any burnt connector you can also check continuaty on the temperature contoller. Good luck.
Please disconnect the power to the stove befor attempting any of the above.
Sep 22, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Our Electric Amana Self Clean Oven, the broiler is not working? Help! The oven and stove top work just fine, but when we go to turn on the broiler the broiler doesn't come on, the selection buttons all...
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Feb 21, 2009 | Amana ARGS7650SS Gas Kitchen Range
Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Feb 20, 2009 | GE Kitchen Ranges
My oven wont heat up.
can you tell me the model # off the stove. sounds like you may have to replacet the TOD or the heat probe.
Jun 24, 2008 | GE JGBP28 Gas Kitchen Range
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Maytag MGR5751AD Gas Kitchen Range Logo
270 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
