Question about Canon CLC 1180 Copier
E020 sub-error 0273
Printer Canon CLC 1120, we add all toners, then a copy was made, it`s was beautiful, I thougth everything was rigth, but it was the only copy that we can made, it`s seems like cyan toner it`s the one that is giving problems, please help me.
  • 67 Answers
Go into service mode function or adjust and put in all the door spects take machine off then on do a graduation adjust
Posted on Nov 27, 2008
Error e020 0180 on canon imagepress c1 please give me a reply
getfile.asp?rid=1258 November 02, 2010 getfile.asp?rid=3215 Product : imagePRESS C1 / C1+ Title : E020 with Multiple Sub Codes for all Colors Problem :
Solution :
Check for a pinched or damaged wire harness from PS3 Patch sensor #2 from connector J426 back to the Side Driver p.c.b at connector J3415 and at PS7 ATR sensor from connector J209 back to the Rear Driver p.c.b. connector J3802.
getfile.asp?rid=33199
getfile.asp?rid=33201 Canon USA, Inc. Systems & Technical Support Division
Dec 19, 2010 | Canon CLC 1120 Color Copier
ERROR E020 03FF
toner clogging between sub hopper and developing assembly
May 24, 2010 | Canon CLC 1140 Copier
I have a problem with code E020 (canon 1120)
E020 - The toner is not adding correctly into the developing assembly.
1) If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) If the hopper is 1/2 full or less, the worm gear splits under normal use.
1) Advise customer to add toner only when the toner light is lit, right away, and replace toner motor, or 2) Just replace toner motor (FH7-1762-030).
After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
After verifying that all is well with the toner hopper unit, consider the DC controller. It has been noted that some DC controllers do not provide sufficient current to drive the hopper motor. Replace the DC controller COL97.08.25 M0000244.txt.
Apr 14, 2010 | Canon CLC 1120 Color Copier
Error code e020 with sub code 140 on canon clc
This code refere the developing assembly locking plate.Please verify the plate mounted and the developer sensor,the toner hopper sensor or the toner hopper motor.
Dec 12, 2009 | Canon Office Equipment & Supplies
E020 01BO What does this error code mean?
E020 indicates a Black Toner malfunction. If you've recently changed the toner and failed to distribute the toner by gently shaking it from side to side, this could be the cause of this error or if the toner is very low it could trigger the same error.
01B0 is a drum error related to your toner error message. If toner cartridge is good, remove the cartridge, clean the drum, replace the cartridge and both errors should clear. A dirty drum will also trigger your 1st error e020.
Nov 16, 2009 | Canon CLC 1120 Color Copier
Canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
E020 0181 or e020 0440
clean your toner sensors take machine off then on doa develpoper stir int then do a graduation adjust
Aug 22, 2008 | Canon CLC 1120 Color Copier
Error Message E020, 0400 for canon CLC 1120 Color copier. please give your assitance
This error has to do with Toner concentration of the Black ( 04 ) part of the sub code. The "00" has to do with the reference level or signal value for black. Look to see if the Black toner sensor is soiled. You have to swing out the toner hopper assembly to access the sensor. You will see two thin gray cables coming down from under the control panel. Since you have access to both assemblies - toner and paper jam detect - carefully remove both and clean with canned air. Be careful since you are so near to the $800 drum. Replace both and test. If you still have problems and the drum is old, several years, and has over 40,000 copies on it, you may have to have the drum changed and I recommend a tech do it. Good Luck.
Oct 29, 2007 | Canon CLC 1120 Color Copier
Canon CLC 1180 Copier Logo
117 people viewed this question
old marine
old marine
