You need to replace the capacitors on the DM board. Its a very easy repair. You can get the V23 DM repair kit at the following link which is the one for your model. Its listed under the repair kit category and comes with the replacement capacitors and step by step instructions on CD. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: mitsubishi WS-55513 won't turn on
Two choices =
1) Replace DM MODULE. 650.00 is right.
2) Rebuild DM MODULE. Done right = a little less than Mits.
Caution: High degree of skill needed and ask about warranty
in either choice.Rebuilds usually cover only parts installed,
not complete module.If you do the research on repair,you
will find pin push reset does not work,in most cases....T.
SOURCE: Mitsubishi WS-55513 blinking light
dear,
did u tried by replacing cap. if not then check it plz
regards,
dont rate it untill it helps or solves
