Question about Dishwashers
Brada dishwasher EF2401 - water in bottom
My Brada dishwasher is not draining and is beeping halfway into the cycle and not finishing. There is water in the bottom.
We just moved into this house and can't find anyone to fix this model...
Please help!
Thank you,
Shannon
  • 2 more comments
  • Francois0010 Nov 26, 2008
    I can't find the Brada site, I would like a owners manual.
    Thanks
  • Anonymous Dec 11, 2008
    can't find manual and have problems with water not draining
  • Anonymous Feb 02, 2009
    I have the same problem as well with no one to offer us any assitance on how to fix it. There's an error code of "E4" on the display and that's it! Help!
  • Anonymous Mar 14, 2009
    My 1 1/2 year old BRADA piece of **** dish washer is doing the same thing, Leaking at the white pre molded plastic water line that ties into the Y split and the center water blade. This is in my new home as well, damaging the floor and my nice oak lower cabinets. I called the Brick, They gave me a 1800 360 2742 number to see if there is any waranty, NOT. I'm kicking mine to the curb and buying a Matag or BOSH with extended waranty. P.S. I gess thats what we get when we chiep out and buy planned obsolesence piece of **** BRADA dishwashers .
    Signed not happy consumer.
I just moved in to a new house with brada dishwasher, everytime I used the water leeks from the bottom, can somebody help me to fix it, or do you think I should throw it away and get a new one.
Posted on Aug 08, 2010
There is a float on the bottom right front side of the dishwasher. pull out your washer and reset the float. Back in action!!!!
Posted on Sep 16, 2010
  • courtneyljos
    courtneyljos Sep 10, 2012
    Where exactly is the float reset and what does it look like?
For your E4 error, it means you have over filled it abd there is too much inlet water (according to the manual)
Posted on Apr 09, 2009
Yes my dishwasher drained all over my floor instead of in the sink any suggestions it is a portable.
Posted on Nov 18, 2011
  • Shannon Beaven May 01, 2013
    I have the same problem.Cost me 130.00. I need a new pump for my Brada. Can't find any one who sells parts for my dishwasher . :(
Anyone have a manual??? I just moved in and the thing stops in the middle of the cycle. And don't know what all the buttons mean. Help!!!
Posted on Jul 11, 2011
  • honeybunny77
    honeybunny77 Jul 17, 2013
    i have the same dishwasher as all you's and i don't have any problems with mine. and Laura with it stopping in the middle of cycle that is the soaking cycle it only does it for a few mins then starts again. the button on the right of the display is a timer. the one on the far right are in this order, Auto, Pots and Pans, Plates, Bowls, Pre rinse, Glasses, and glasses and cups
Try removing the dish rack completely out of the dishwasher. This will allow you to access the cover/plate inside the dishwasher at the front in the center . Remove this plate (there is a little handle you can use). Then take a 1 cup mneasuring cup and scoop as much of the water as you can by putting the cup in the deepest part of the dishwasher - it is in the area under the cover/plate(this is why you remove the cover/plate). Put the dish rack back in run the cycle again. This should fixya! = )
Posted on Jun 30, 2009
Brada dishwasher EF2401 BS, error code E2, will not go to wash cycle it appears and starts beeping. There is no water sitting in the bottom. We have taken out the drain and Cleaned the filter basket
E2 - Abnormally long drain time. Check to make sure that the drain line is not obstructed or bent in a way that restricts water flow. Make sure the drain line is routed below the height of the dishwasher and that it has not been extended. This will inhibit the ability of the drain function to operate properly.
ref. https://support.edgestar.com/hc/en-us/articles/201075515-My-dishwasher-is-displaying-an-error-code-What-does-it-mean-
Dec 17, 2017 | Dishwashers
My cda cw496 dishwasher beeps in the middle of the cycle and then water leaks from the bottom. any suggestions?
The problem could well the plumbing past the machine... Are any of your other drains in the kitchen slow? A little snaking of the drain lines may be in order.
Jan 02, 2015 | CDA Dishwashers
My Fagor dishwasher di not finish the cycle and has water in the bottom of the machine which has not drained. Now it will not start and just beeps. How can I drain the water and get it to start and fu
A small amount of water in the bottom is normal (it allows the pump to be pre-primed). Do not remove the water (as long as it is only a little in the center well).
Nov 03, 2014 | Fagor Dishwashers
Hoover HFI 3015 integrated dishwasher beeping on each program cycle selected
Check out the micro switch on the door seems to not indicate that the machine is properly closed or your outlet pump is blocked and needs to be cleaned out,cause it is clogged up and cant remove water properly
Jan 06, 2014 | Dishwashers
Wrong dishwashing liquid used created out of control suds won't finish cycle. cleaned away suds towel and wet vac but foes not work
HI- Ah yes, the suds. Your flood switch has probably been tripped. Unplug the machine or flip the breaker. Remove the lower kick panel and you'll see the white plastic bottom of the dishwasher pan. This is designed to catch the water (or suds) if there is a leak or the water (or suds) over fill it. This will take awhile but get some pliable rag and carefully put it in the space between the bottom of the dishwasher and the pan. There is a styrofoam float on the left side about halfway back, this has to be down for the dishwasher to advance the cycle and get out of drain mode. Just keep soaking the water up (you kinda have to go over the plastic lip of the pan and down wherever there is an opening large enough to get the rag into. Once it is pretty dry it should run ok. Regarding the suds. If you get the machine to run ok then start a rinse cycle and once the water is done filling open the door and add about 4 tablespoons of any cooking oil to the water. Shut the door and let the machine run for about 10 seconds, open the door check to see if there are still a lot of suds, if so cancel the cycle to drain the machine and repeat. Hope this helps, good luck.
Sep 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Brada dishwasher ef2401 wont start wash cycle
If it's under warranty, get someone to look at it. Probably a bad switch or sensor in the unit, could be something simple, and they're not hard to open up, but the soap dispenser mechanism has to be reassembled (it often falls apart upon taking the door apart). Last resort is the appliance serviceman. New house? New dishwasher? Warranty? That's your best option.
Mar 13, 2010 | GE 24 in. Profile PDW7800 Built-in...
Cycle finishes but water is not draining
Sounds like too much water leftover.
Give me a make and model number of the dishwasher.
Check that the drain hose isn't kinked, and that where the drain connects at the garbage disposal at the sink isn't partially clogged. And, is the garbage disposal clean/clear of food stuff's.
I had a similar thing happen to me a few weeks ago, and it turned out the kitchen sink drain line was clogged.
Dec 16, 2009 | Cars & Trucks
BRADA dishwasher looking for manuale and instructions to operate
Sep 13, 2009 | Dishwashers
Brada ef2401 door won't close
We actually had the same problem with our Brada dishwasher. There is a plastic clip inside the door that latches on to the dishwasher to keep the door closed. In our case this clip had flipped inside the door (periodically continues to happen to this day). To resolve we took the door apart - carefully - and flipped the clip back into proper position. You can only do this if the dishwasher is not under warranty as once you take it apart you will likely void the warranty on it.
Aug 12, 2008 | Dishwashers
Dishwasher not draining
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
Dishwashers Logo
6,785 people viewed this question
Top Dishwashers Experts
