Does the fan of Kenmore 50 pint dehumidifier runs continuously or turns on only when the humidity level rises above the set point? i am planning to buy one but I need to know the answer to my question.
Thank you,
Bob, some humidifier fans run a lot, because they are designed to keep the air moving and when the humidity level rises, the compressor turns ON to extract the humidity. If you're operating the unit in a continual mode, it's not unusual for the fan to run almost constantly.Especially, is the humidity extraction level is set at or above 50%. Lowering it to 35% will cause it to extract more humidity and will turn on an off less.
Hope this helped you and thanks for choosing FixYa.
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Kathy, I'm not sure you have a problem with the dehumidifier. Depending on which mode you're operating it in, the fan will run in an effort to recirculate the air. If the humidity level rises above the level you have the unit set on, the compressor will then turn ON. This is particularly true, if the unit is operating in continual mode. Then there are other times the fan isn't active, but the compressor turns on when the humidity sensor feels a rise in humidity. So, for the most part, I don't think it's a problem.
Just be sure that you clean the air intake filter at least once every two weeks, during times of daily operation.
Chucke - Depending on which mode you're operating the unit in (Continual Mode), yes that is normal.The fan continues to run in an effort to recirculate the air. If it senses a rise in humidity above the level you have it set on, the compressor will turn and remove that humidity.
That depends on the manufacturer and in what mode you are operating it. If it's Continuous Mode. Yes, the fan will continue to run, as it's recirculating the air, in an effort to determine if and when the humidity level rises. Then the compressor will turn ON to extract the humidity.
Also, most units will do this if they are running thru the Defrost Cycle. This happens when the cooling coils frost over. It to, is a normal cycle.
So, if you are operating the dehumidifier in Continuous Mode, it's acceptable. \ Hope this helped you. Please let me know. Thanks.
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture. humidity will be extracted from the air. On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
According to the Owner's Manual for your model, the fan will run continually, if the unit is set in continuous mode or if the unit is in defrost mode. Once the unit senses a rise in the humidity level, the compressor will start up again. Also, a dirty or clogged air filter will cause the fan to run more that it should.
Hope this helps you troubleshoot and solve the problem.
The model you have was made by Fedders for Maytag. The fan runs as a recirculating fan, to continually sense when the humidity level rises, above what have the unit set on. Here in, may be the problem. If you have the humidity level set higher than 50%, that's pretty high and the unit want remove much if anything. It will just continue to maintain that level. Keep in mind, the unit's humidity level must be set LOW, for the compressor to kick on and start removing humidity. By low, I mean 35% or minimum, if your unit does not have an LCD display.
I must caution you, that there is associate on this website that would tell you, that the level should be set on Maximum. Believe me, that simply is not the case. That is, unless you want your home to be hot and humid.
Hope this helps you to troubleshoot and solve the problem.
You may have the humidity level set to high. Usually anything above 50%, will show little results, unless your house is flooded.. Turn the humidity setting to the lowest level that your humidifier has and give that a try.
The fan runs a lot, because it's designed to almost constantly move the air around. That way, if the humidity level rises above the setting on the dehumidifier, it can sense it and the compressor will turn ON.
