Error messages sometimes appear in the status panel on the back of my Fun! Digital 320 camera. What do the error messages mean?
I suggest that you hook the camera up to the computer and try turning the camera on if the green light then becomes red hold it down so that your photos may be stored on your computer then before uploading images then you press delete images from camera after there loaded then see if your camera works
The following is a listing of the error codes you might see on the status panel of the PhotoMAX Fun! Digital 320 camera: 1.FL - Photo memory is full. You cannot take more photos. Download and then erase the photos in your camera. 2.FE - Flash memory error. A camera hardware error occurred. This can happen when the power is shut off before a photo is completely stored in the camera. Do not shut off the power until the green light comes back on steady after you take a photo. 3.bE - Hardware problem. Turn the power switch on and off and see if the error message disappears. If the error message persists, the camera may need to be replaced. 4.Lo - Battery low. Replace the camera battery as soon as possible. If you continue to use the camera, picture quality will be poor. 5.LL - Low light condition. The camera does not have enough light to take a good photo. Improve the subject lighting if possible. Example: When taking indoor photos, add additional room lighting.
