Question about Fuji FinePix A303 Digital Camera
Slow camera Thank you for the suggestions. I got the camera about 6 years ago and it worked fine. The problem started recently, over the last few months. It cannot be related to the card, or the processor. They were the same when it worked well. It is charging up very slowly. I think it is either a capacitor or a rechargable battery that lost performance over time. Do you know anything about the inside battery?
  • 52 Answers
Unfortunately, the externals you use are AA's so I'm sure you've tried new ones there.   The internal battery (or capacitor) is not worth attempting to replace for a camera of that age. You may end up spending more to replace the battery then you would to upgrade to a new, higher resolution camera.  Good Luck,  NGK
Posted on Sep 05, 2008
Hi. i have sony w120. its not new, i bought it cca 3 years ago. I didnt use is for a quite a while (but my family did), so few days ago, i realized when i take pictures, pictures are somehow blurry,...
Please go to Setup menu and select Initialize option to reset camera to default settings that might solve blurry picture problem, if that does not help then its technician job to adjust focus of camera.
Thanks.
Aug 02, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Tip
I have the same problem with a Canon Powershot s20. Bought approx 5 years ago...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Jan 28, 2008 | Samsung Digimax D53 Digital Camera
I am using this camera from last 3 years. It was working fine. Suddenly, a problem occurred. Now whenever I select the Auto mode, it is set to video option instead of still image. I have formatted...
I'm have the exact same problem. Purchased the camera 3.5 years ago. Recently needed to shoot a video, when finished I set the camera back to Auto and it stayed in video. Portrait mode shows manual, all other modes work as assigned. I've noticed at least TWO other posters having the same problem within the last couple of months. It's as though this camera (mfg. 2007) has a Trojan program from the factory to make us buy newer models.
Other than resetting, is there a way to flush and reload the firmware?
May 06, 2011 | Canon PowerShot A570 IS Digital Camera
My bravettii slow cooker would not cook baked beans they cooked for 18 hrs total 6 hrs was on high and 12 hrs was on low and the beans are still not fully cooked it never came to a boil is there...
I can't solve your problem but I can sure relate. I am having the same problem with my Bravetti Pro (it's far from Pro - it should be called Bravetti Amateur) I tried cooking a small ham with cut up potatoes recently, and after 11 hours cooking at the medium setting, the potatoes were not cooked. I got this thing as a gift about a year ago, and although I've only used it a few times, it never seems to cook properly. Mine was purchased at Canadian Tire and although I don't have a receipt, I think I'll try to take it back. Good luck with yours!
Tom
Feb 08, 2011 | Bravetti PC107HA Slow Cooker
When I recently turned on my camera (D-630 Zoom) to take a picture, I got the message titled Card Setup, with two options "Power off" and "Format". I turned the camera off, took out the...
If this exact card has worked in the camera before, chances are it has gone bad. Typically, if the camera says to format the card it is because it does not recognize the card. The only reason this would happen is if the card is unreadable from malfunction, or it is too new of a technology for the camera to recognize.
Dec 17, 2010 | Olympus D-630 Zoom Digital Camera
Easyshare C713 LCD view is flushed out.
you push on the little 'i' button thats right under the delete button.
May 14, 2009 | Kodak EasyShare C713 Digital Camera
Slow rotation of the ceiling fan
Who do you think is 'you'? Electronics technician indeed. Take it down hot from running and find out what's sucking up all the juice; bearings, windings, controls, etc.
Don't take a year at servicing things if you can help it....
Aug 12, 2008 | Dryers
Quantary 100-300mm telephoto lense
I have been researching this problem and found there's nothing you can do. Appararently, the quantaray, being an older lens, wasn't made to work with this latest era of cameras. Though it might work perfectly with your older camera, its technology is outdated as it relates to digital cameras and can't mesh with the latest and greatest. By the way, most of my questions were answered on the Digital Camera Resource page (www.dcresource.com)
Jul 25, 2007 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Losing power rapidly...
The only thing I can suggest is that the metal connections on your camera have corroded due to the long life of your camera. I had a similar problem where any batteries I used would not work, regardless of what kind of battery it was. Turns out I had a nice greenish layer of corrosion on my connections which I sand-papered off. This might be a little tricky if your connectors are way inside of a battery holder, but it can be done nonetheless. Try taping some sandpaper to the flat end of a pencil and clean it out that way. Hope it works.
Jun 25, 2007 | Canon PowerShot S1 IS Digital Camera
Fuji FinePix A303 Digital Camera Logo
44 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
