Question about Garmin Nuvi 350 Car GPS Receiver
Nuvi350 stuck in FMI mode!
I used the Nuvi350 in FMI mode by plugging the Garmin Data cable into the side data port. Worked great! I have removed the data cable but the Nuvi still stays in FMI mode.
Does anyone have a way to return to non FMI mode without resetting the Nuvi back to its factory defaults and losing all my settings?
  • 2 more comments
  • Anonymous Oct 18, 2008
    I have the same problem! I tried to revert to factory default but still see the custom FMI menus
  • Anonymous Dec 27, 2008
    I have an identical problem! How can the Nuvi be reset to non-FMI mode?
    SHARCNET-USA May 11, 2010
    You must mean the traffic receiver.
    The 350 has FM?
  • 2920 Answers
SOURCE: garmin nuvi 660 lost map data
take it back to the store you got if from and get a tom tom
Posted on Aug 25, 2008
  • 52 Answers
SOURCE: Garmin Nuvi 760 loses satelite
You may need to buy an additional external GPS receiving antenna. I did for my 750.
Because we love our electronics so tiny, they use an internal antenna. The gold input on the back of it, is for an external antenna available for under $20 from ebay. I used it when I lost reception in NYC, and also in rural areas. The external one has q magnet on it, and you can put it on the roof and have the cord come in your window to the unit (better than arm out window!)
check here - where i bought mine
Enjoy, NGK
Posted on Sep 03, 2008
  • 3 Answers
SOURCE: Stuck in Demo Mode
If you can plug the c550 into your computer and pull it up as a drive, you should see a "Demo" folder. Delete this folder, and it MAY fix your unit. If your computer will not see the unit, you will need to send it in for repair. FYI, I am an employee at Garmin, and we always go out of our way to help in any way we can without sending it in for repair. Garmin gives us more latitude to help the customer than any other company I've ever worked for. We don't do anything "just for more money" We don't work on commission, we get nothing out of making the customer pay for a repair.
Posted on Dec 10, 2008
  • 2335 Answers
SOURCE: New Garmin nuvi 255w suddenly not working
Those are severe symptoms.
A Hard Reset is a good idea after a firmware upgrade.
There are three levels of getting your Garmin 255W's attention and correcting bad habits (ie: not loading maps or locking up).
The first is 'soft reset'. There is a reset button along the bottom of your gps. Push and hold it until it restarts. If you cannot locate your reset button, sliding the power switch to OFF and holding for 8 seconds should do the same thing.
The second method is a 'hard reset' or 'clear all user data', to restore factory defaults.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
The third method is a firmware upgrade via Garmin's Webupdater, or the myGarmin site.
Run through these fixes to get your Nuvi running as good as new.
I hope that helps.
Posted on Jan 02, 2010
  • 2130 Answers
SOURCE: Garmin Nuvi 255W, all my data was deleted!
This unfortunately can happen. The 2xx & 2xxW are known to sometimes have the memory corrupted at turn on. Be glad you didn't lose your map or system software. I can understand your frustration losing your favorites.
The next time, once you have all of the favorites back in, connect your Nuvi to the PC and make a backup of the file "current.gpx" from your gpx folder. This will allow you to make a backup of your favorites.
- Jim
Posted on Jan 12, 2010
Where do I find a 6 pin serial to usb adapter for the Garmin 421s? I can't find one anywhere on line. Does Garmin sell one? It's Saturday and Garmin's help center is closed. Their on line...
The 6 pin DIN plug found on the GPSMAP 421s data/power cable (Garmin part number 010-10918-00) is used for the sonar input.
Data transfer from the GPSMAP 421s is easily transferred by memory card.
Information about data transfer on the 421s is at about 50 seconds into this video.
Real time NMEA data can be transferred using Garmin part number 010-10918-00 wired to a DB-9 serial connector (Instructions are on the cable).
It then can be adapted to USB using a serial to USB adapter.
Sep 17, 2011 | Garmin 421S GPS Receiver
My Garmin Nuvi 250 w gets stuck on the screen showing a picture connecting a computer to Garmin. I have it in my car and resetting hasn't worked. any suggestions
The nuvi is being put into mass storage mode (the mode used to transfer data back and forth to a computer). This is usually caused by using the wrong vehicle power cable.
The correct cable is Garmin part number 010-10723-06.
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
I have a garmin gps 12--s/n 35854358. No auto-locate?
If you haven't used the gps for a while they can try to operate with the incorrect catalog or time. Unless these are both correct it gets lost. Usually you can correct this with a forced reset. There is also a update for this unit which also forces the update.
The data cable sort of screws on and makes contact with 4 pins. This is the little round connector. It does both power and data. The cable is a wee bit pricey from Garmin but you can make them or just get one from ebay.
The reset usually wipes out any saved routes poi's etc so using the data cable will save all of those. To reset the 12 I believe you hold the lower right corner of the screen and then power it on to reset. Then you need to let it rub until it gets the new data which can take 5-50 minutes. Makes sure your batteries are good.
I'd recommend the data cable route (use a 'gasp' non garmin cheap cable) and upload the update at the same time and you should be good to go try and get lost again.
Jun 28, 2010 | Garmin GPS 12 GPS Receiver
ETrex legend serial to usb cable problem
Have you tried using the cable with another device just to check it's working ok.. And try a different usb port also, they can be funny that way.
A Garmin rep I spoke to about this told me (off the record) to just go to my local electronics store to pick one up for app €15 as the same thing from Garmin would be about €75. So it's basically the same cable and should work. I tried it with a generic cable here in the shop and it worked in one usb port but not in the other two so a bit of trial and error is needed.
All that failing I'd bring it back to the shop and ask them if there is a different type you could try, possibly you need one with a higher data transfer capability.. But try the cheaper and easier options first..
Oct 07, 2009 | Garmin eTrex Legend GPS Receiver
Nuvi350 won't power on from USB or power jack, works fine in car
Bad contacts with the mini USB port. Either the connector needs resoldered or replaced. Please see this link, section on loose/broken USN port:
- Jim
Jul 06, 2009 | Garmin nuvi 350 GPS Receiver
Garmin 200w goes into usb mass storage mode when pluged to charge
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Jun 08, 2009 | Garmin nuvi 200W GPS
When I plug in the Garmin to charge it, the screen goes completely black and I get no directions. When I unplug it, the map returns with directions. Please help , Thank you James
If you are plugging it into your computer, or charging it through the USB port, the Garmin NUVI will go into "DATA MODE". You must use the car cradle to charge it and stay in navagation mode.
Mar 23, 2009 | Garmin nuvi 750 GPS Receiver
Garmin nuvi 660 lost map data
Aug 24, 2008 | Garmin nuvi 350 GPS Receiver
Check Factory Data after fixing convergence and resistors
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
May 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convert a USB power/data to power only
I have found a partial fix for my problem at
This explains why a mini-usb "sees" data/power or just power. It has a different resistor between X and ground - the 4 pin. 200K ohm for data/power and 17.3 or 22K ohm for just power.
OK - where does this resistor "live" in the cable and what do I have to break to get at it to change it OR is there someone out there making a USB to mini-usb power only?
Feb 08, 2008 | GPS
Garmin Nuvi 350 Car GPS Receiver Logo
260 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
