Question about Polaroid PhotoMax PDC 640 Digital Camera
How do I the delete images so I can re-use the memory card?
The memory card appears to be full in my PDC 640 digital camera, because I can't take any more pictures. How do I the delete the photos so I can re-use the memory card?
    Master:
  • 450 Answers
To delete photos from the SmartMedia memory card in your camera, you must first download them to your computer. Follow this procedure to transfer your photos from the camera to your computer: 1. Make sure that your PDC 640 is connected to your computer and both are turned on. The "PC" icon should appear on the status panel on the top of the camera. 2. Open the PhotoMAX application on your PC. 3. Click Get Photo. Note: If you are using PhotoMAX Pro to transfer pictures, you need to select PDC 640 Camera from the Select Source dialog box (select File > Acquire > Select Source), and then select File > Acquire. 4. Click Album or flashPath. 5. Select the album in which you want to save your images, or click New Album to create a new album. 6. Click Camera or Scanner. 7. Select PDC 640 from the Sources list on the Select Source window, and then click Select. The PDC 640 Twain Driver window opens. 8. Click Get All to transfer all the images in the camera memory to your computer, or select the images you want to transfer to your computer and click Get Selected. The images are transferred to the selected album, which is located in the PhotoMAX Albums folder. The PDC 640 Twain Driver window closes. 9. To edit a picture, double-click the image in the album that you want. The image appears in the image tray.
Posted on Sep 21, 2005
SOURCE:
I cannot capture new pictures with my polaroid pdc 2030 digital camera . I get error message FUL when the shutter is depressed .
When you download does it delete the pictures automatically or are all your pictures still on it. It sounds as though the internal memory or memory card is full and you will need to delete some pictures or format the memory after you have downloaded them to your PC.
Jul 23, 2016 | Polaroid Cameras
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
Have a PDC 640 10 years old and need a driver for my DELL cumputer with Windows 7 Premium
You are not likely to find a driver for a camera that old. Why not use a card reader instead? Just pull the memory card from your camera, insert it into the card reader and plug that into your computer. It is simply, fast, and doesn't drain your camera's batteries.
You can get one at this site: http://www.memorysuppliers.com/daz6in1mulre.html
Mar 19, 2010 | Polaroid PhotoMax PDC 640 M Digital Camera
Message Display
sometimes this problem occures due to defective or fake memory media. try using a good branded card.
Sep 09, 2006 | Panasonic Lumix DMC-FZ10 Digital Camera
My PDC 640 digital camera's memory locks up (when I'm using a memory card). What should I do?
The camera memory may "lock" as it reaches its limit. With the camera disconnected from the PC, and on battery power, turn off the camera by closing the lens cover. Remove and reinsert the memory card. Now turn on the camera -- it should power on properly.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Transfering pictures using the FlashPath Floppy Disk Adapter?
To transfer pictures: 1. Remove the memory card from the camera. 2. Insert the memory card into the floppy disk adapter. Make sure that you insert the memory card into the adapter with the gold side of the memory card facing you and to the right and the silver side of the adapter facing away from you. 3. Insert the floppy disk adapter into the diskette drive on your computer. 4. Double-click the PhotoMAX shortcut on your desktop to open the software. 5. Click Get Photo. 6. Click Album or FlashPath. 7. Click Downlod from FlashPath. The images appear as thumbnails on the album manager window. 8. Double-click the image that you want to edit. The image appears in the image tray. 9. Remove the FlashPath Floppy Disk Adapter from the diskette drive when you are done.
Memory card?
The PDC 700 digital camera has 4 MB of internal flash memory on which to store images. An optional ATA-compatible Type 1 CompactFlash memory card gives your camera substantially more memory, allowing you to store more images or images of higher quality. images captured on the CompactFlash card can be downloaded using the same method as you use to download photos from the internal memory.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
USB port with the PDC 640 camera?
The Polaroid PDC 640 digital camera connects to an available 9-pin serial port only -- it does not support the use of a USB/serial converter. However, you can use a SmartMedia Card Reader with the camera's reremovable memory to download the images via the USB port to your computer.
Is it possible to recover my pictures?
You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead.
If and when that happens, then it becomes too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.
If the deleted files are on a memory card or USB memory stick, just don't save any new files to it.
One of the easiest ways to see if you can recover deleted photos is to try some picture recovery software. Recommended asoftech photo recovery as it saved my life many times.
http://www.asoftech.com/apr/
My system locks up when I attempt to download images from my PDC 640 camera.
While it appears that the system is locking up, the actual problem is that a message prompt in the PhotoMAX 2.0 software is hiding beneath other open windows and needs to be answered before proceeding. In this instance, the PDC 640 TWAIN Driver window has been preset to always be the "top" window, obscuring any other windows that may be open behind it. The PhotoMAX 2.0 window must be "active" (or "brought to the top") to answer any message prompts. Once the message prompt is answered, you will be able to download images. To deactivate the PDC 640 TWAIN Driver window's "Always on Top" preset: 1. Launch the PhotoMAX application. 2. Select Get Photo. 3. Select Camera or Scanner. The Acquire From window appears. 4. Select Twain device and click OK. The Select Source window appears. 5. Highlight PDC 640 and click Select. The album window appears next, followed by the PDC 640 TWAIN Driver window. 6. Right-click on the PDC 640 TWAIN Driver window and deselect (i.e. uncheck) "Always on Top". To move the PhotoMAX 2.0 window forward: 1. Launch the PhotoMAX application. 2. Click on Get Photo. 3. Click on From Album. 4. When the album opens, answer YES to the question "The contents of this album have been changed. Do you want to save the changes?". 5. Click on the Acquire icon at the top of the album window to select the PDC 640 camera and download the thumbnails from the camera. Your system will no longer appear to lock up.
Sep 14, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Polaroid PhotoMax PDC 640 Digital Camera Logo
128 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
