Question about Honeywell Programmable Thermostat Heater
I installed the honeywell vista 15p and everything works, but I connected the comet pet PIR and can't get the led light to come on eventhough the system says ready. I'm not sure i connected it right. I connected the power and - to the power source, but am not sure how to connect the tamper and alarm leads. The line leading to the control panel only has 4 leads; black, red, green, yellow. I ran a test light on each line and they are all good.
    Problem Solver:
  • 13 Answers
Leave a short jumper wire between the tamper terminals.
Connect red to +12v and black to -12v on the Motion Detector.
Connect red to Terminal-5 and black to Terminal-4 on the Vista-15P
Connect Green & Yellow to the alarm terminals on the Motion Detector,
Connect Green & Yellow to the desired zone on the vista panel, be
sure to add in your EOL 2K resistor (if using them) in series along
either the Green or Yellow, preferably at the motion, but can be in the
panel box if it's not a "high security risk" install (most residential
systems have them in the box, although any security professional
will say it's not "proper" but go ahead and check other boxes, you'll see).
I think BRINKS is the only one to do the true "end of line" procedure,
but it's a royal pain in the @$$ if you ever change panel types, you have
to pull every wired sensor out just to change the resistors, and if it's a
prewire (put in when the house was built) it's nearly impossible without
rendering the wire run useless unless there's a lot of slack on the line.
Check your vista installers manual for the rest! Good luck!
Posted on Jul 04, 2009
PIR switches and house wiring is incompatable?
Several possibilities. First use standard light bulbs until it is working. Some of the PIR have triac outputs which need a minimum amount of current to work. CFL and LED lights can be a problem with electronic switches/dimmers.
The PIR needs electricity to operate. The black and white wire are probably power and return, there is no neutral to connect to the PIR. Unless you can get a different PIR that does not need line power to operate you are out of luck. There may be some that can cycle steal power and would work but I am not familiar with them.
I assume the three way is a three way PIR and the lights that are flickering are electronic such as LED or CFL.
If you talk to one of the people where you bought the switch they may help you free of charge.
Good Luck
Feb 23, 2014 | Electrical Supplies
What is a long range radio trouble
It indicates a problem with your cellular radio or that your alarm system is programmed to look for one that is no longer working or connected to your system. This can be disabled in installer level programming.
Aug 21, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
Can't access installer code honeywell vista 20p
Power down the panel, remove the battery. Hold down the * and # while re-powering the panel. It will jump right into programming. Release the *and # button and proceed with programming.
Apr 07, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
How to remove the FC phone system part from a honeywell vista20p
To properly solve the problem, the system must be reprogrammed using the installers code.
Nov 09, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
Trying to get installer code on Honeywell Vista 15-P
hit *20 then put in whatever 4 digits you want as installer code. write this down on your program sheet for future reference. yes, you should have a program record sheet to follow and know how to navigate in programming or else you could make things worse.
Jun 29, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
Honeywell vista 20p FC error code no monitor service beeping every 30 sec. need help how to stop beeping
If the keypad displays FC, that means that it is programmed to send alarms to a central station and a phone line isn't connected to the control panel. If you do not subscribe to monitoring services, it will have to be re-programmed. I can do that for you over the telephone if needed.
Thanx Mark Garrett
Aug 21, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
My Honeywell Ademco 6160 Alpha Keypad Vista 10E low battery light keeps flashing even after I've change out????
The low battery light will stop flashing when the new battery you just installed become fully charged. It will take some time for the new battery to become fully charged.
Jun 06, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
6160 key pad "open circuit"
open ckt on the keypad refers to the data lines going to the keypad. check to make sure the yellow and green wires from keypad are properly connected.
Feb 17, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
Heating & Cooling Logo
146 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
