Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Kv-32s120 standby LED blinking no sound or picture
The tube dosenot seem to power up no picture or sound
  • Rstettler Sep 10, 2008
    When the power button is pushed, light blinks 7 times slowly, then when changes to 7 fast blinks. Picture never comes on no matter how many times the power button is pushed.
The led next to my power button flashes nonstop on my sony wega kv27fs320
what do i do thanks
Posted on Sep 11, 2008
    President:
  • 1,284 Answers
How many times does the timer light flash between pauses?
Posted on Sep 08, 2008
KV-36XBR400 won't turn on, "standby/stero" light
You are correct. You are right about the power supply and replacing with led hdtv. You will be happy with a Samsung led. Time to upgrade.
Mar 04, 2011 | Sony KV-36XBR400 36" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Sony kv-27s42 no picture no sound can here relay click
I will look up your specific model to be sure, but teh 3 blinks usually mean a power supply problem. Stay tuned for more...
Dan
Aug 23, 2008 | Sony KV-27S42 27" TV
Blank screen on startup on Sony KV-32FX20U
All Sony sets will stay blank until the circuit is ready to power the tube. If there is a problem detected inside the set, the tube will remain vlack and the standby light will blink. This blinking will repeat a count as follows: Blink count, pause for a second or two, repeat the blink count, etc. Some Sony sets will play for a while then flash off and on. This is usually an indication that the picture tube is starting to fail. In your case, you should see a blink code. If you can update this with the blink count, I can use that info plus the model number listed above to provide a possible cause and the parts required to repair the set.
Dan
Mar 29, 2008 | Sony KV-32FX20U 32" TV
Sony KV-28CL10U TV
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 08, 2017 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
279 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
