Question about Samsung SGH-D900 Cellular Phone
Samnsung r410 each time i turn it on the samsung screen stay there and keep going on going on da same screen that pops up when you first open it
    Brigadier General:
  • 7,752 Answers
You firmware needs to be reflash so take the phone to a mobile service center and have them correct the issue that you are having.
Posted on Sep 06, 2008
My sony ericsson play has a blank screen how do i repair or reset it?
ma f'in fone got ribbon problem x'play screen stays blank but everything working fine but I cant see whats going on !! I have tried to repair that **** for ma self but I couldnt open bluuudy one screw drive bcoz it was freaking damaged and it look like f'in old screw f'in chinese mn did not have freakin enough screws !! any idea for da bluddy old chinese screw out ? if dont no worry da phone will be sent to da f'in made in china were born in Japan **** ma LAN im done bluddy chinese run b4 I get da gun keep on run shoot ya to japaan.....
Jan 02, 2012 | Sony Ericsson Xperia Play
I have a Samsung SyncMaster 931BF. I love the screen, but for quite awhile, the screen has been having a hard time coming on and staying on. I'll have to cycle the power multiple times to get the screen...
Remove its stand
Unscrew all the screws in the back.
It doesnt just lift off I guess you could say, there are many clamps around the edge that need to be "popped" by sliding anything thin enough to get between the front and back of the case to pop them.
I popped mine open the other night. The clamps appear to be hard to break, at least in my circumstance. None of them broke with a fair amount of pressure from pulling being applied.
Also, mine had your exact same issue until one day it no longer turned on completely. It just flashed the screen once and showed a flashing power light around the button. Replacing 3 capacitors that were just barely bulging on the top fixed the issue.
Jul 15, 2010 | Samsung SyncMaster 931BF LCD Monitor
My phone Samsung SCH-R410 will not turn on. The
software problem,
if u wan solute it with your own ,
u need data cable and download the firmware to flash it
Jun 02, 2010 | Samsung SGH-L700 Cell Phone
I can not open pics on my Samsung R410 messenger phone. I keep getting a message that says I dont have enough memory. Can you help?
to open pictures in phone you must need a engough space access it so you first delete and clear unwanted file from your phone and then try it
Apr 25, 2010 | Samsung Cell Phones
When ever I hook up My samsung schr410 it keeps rebooting and will not stop
Try downloading Samsung PST for the SCH-R410... it might work but you have to have the USB cord. It worked for my Messenger II (SCH-R560)... I have the SCH-R410 with the same issue but I do not have a USB cord. Let me know if it works! My email is carcrazy2320@yahoo.com
Jan 19, 2010 | BargainCell Samsung M300, M510, A117, T729...
My phone fell in water and the screen turn white
just open your cellphone completely I mean da battery n all.. then slightly wash it with wd40( the solution from which we wash the pistols n weapons of such kind) then keep it under a table lamp for atleast 48 hours.. inshallah it will clear up ur screen..
Jul 05, 2009 | Samsung SGH-E900 Cellular Phone
I need help unlocking my cell phone. I put a lock code and cannot remember it and now i cannot use the phone to make any calls. Can you please help me? It is a SAMSUNG R410. Thank you, Gina
Unfortunately there is nothing much that can be done. You can try it multiple times around 10 times and then it would ask you for the PUK number, which you can get from the Telecom Service Provider. You can try that and it should work.
Jan 26, 2009 | Samsung SGH-D900 Cellular Phone
Samsung sch r410 boot screen loop
call samsung i had same problem and they sent for it and fixed it for free
Dec 12, 2008 | Sharp 703 Cellular Phone
Sidekick 3 screen problem
This procedure usally will fix a white screen on a sidekick 3 or a sidekick ID.
http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
Try this before you replace the LCD
Dec 06, 2007 | T-Mobile Sidekick® 3 Cellular Phone
I see only horizontal line on TV Samsung CK-5339ZB
h/line is due to vertical section failure. 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor. .5ohm to 10 ohm. it burnt again due to short cht in vertical mainly due to ic. hope this will help. as per schematic diagram go to www.serviceinfo.com
Oct 04, 2007 | Samsung TXN3271HF 32" TV
Samsung SGH-D900 Cellular Phone Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
