Question about RCA HD56W58 56" TV
I change module 267147r only works for 1 min
I change the module whit the fly back is ,I tray to turn on the TV and won’t turn on, I find out that the hv splitter was bad , I replace HV splitter and the TV works for lees then a minute now I have fuse FP 201 blow and the new module is now lake the bad one.
    Genius:
  • RCA Master
  • 1,689 Answers
Most likely the modules you put in also blew again.
The reason is that there is a fault in another section of the set. For an example, the main power supply may also be defective. If its output voltages are not in spec damage will be done.
Many times when there are failures it is very important also locate the cause of the failure. This type of diagnostics can be involved and will require experience with a solid knowledge of the TV set, the proper test equipment, tools, and the service manuals.
The authorized service center is equiped, and has properly trained technicians that can service your set.
Jerry G.
Posted on Sep 05, 2008
When turning tv on it goes in to standby and doesn't come on . I used to be able to unplug it and wait awhile plug it back in and it will come on
one of the convergence ic is defective or shorted try to check or compare the reading to the other convergence to be sure.
Oct 14, 2010 | Sony KP-46WT520 46" Rear Projection...
I have a 54" Toshiba TV Model # 57H81. The only thing it does when I turn it on is a small red light in the front is flashing. Please help me! Thank you so much!
If you have some garbage in the main processor you need to leave it unplug for 40 MIN, to reset it back to normal. If that don't work then you need to check for a shorted horizontal transistor, mounted on a metal heat sink near the fly back transformer, that is what turns your high voltage on.. If that is good , then the next common problem would be is a bad convergence module, and you are looking at around 400 on repairs.
Oct 14, 2010 | Toshiba 57H81 57" Rear Projection...
I want to change the region code on my sony slv d281p
I dont know is this work in your brand, but we dont lost nothign whit try it:
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
Hope helped.
Oct 29, 2009 | Sony SLV-D281P
Won't come on.
check the sorces like video 1 and stuff like that the tv may have a short in it
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F32648 32" TV won't turn on. It just makes a buzzing sound when I plug it in, and it not responsive to any controls. . Is it likely gone, or is there a capacitor, transformer I could change. I don't...
The fly-back transformer and horizontal output transistor is probably bad check Matt Electronics for the parts. the fly is about $25.00
Matt 1-800-811-5177
Apr 19, 2009 | RCA F32648 32" TV
My RCA D52W26 model tv blanks out, but still has sound
First. Resolder fly back terminals. MAybe liquid coolant projection on the board or yokes, ( some times picture tubes is bad . resolder deflection board.
Apr 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Running lights go off and on when turned on
me to please hepl me whit that what you doning whit that my light brack no work
Oct 25, 2008 | 2000 Dodge Grand Caravan
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Sony KV-32HX15U Flashing standby light
Hi. Thats a nice tv you have there. If your able to get free estimate from repair shop go for it. It could only be dry joints but it could be loptx & other components which could be pricey.
Sep 23, 2007 | Televison & Video
RCA HD56W58 56" TV Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
