Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Sony KP-51WS510 I have had my sony since 1999 and had a repair man out 3 times. All 3 times he adjusted the horizontal. It is doing the same thing - white lines across a green screen then shutting off and blinking - 1st 6 times and now 8 times. How do I remove the speaker cover and adjust horizontal myself. Sony of course told me to call repairman again. Set was under warranty - but not any more. I should have paid closer attention to service repair. Thank you.
I have a similar problem... can you help me?
I really need some help with my 4 year old KP-51WS510... The TV was working fine until for about 6 months ago.. The the following started to happen.
1) for the past 6 months, when I turn on the TV, the picture does not fill in for several minutes. Only 1/2 the picture screen fills in (showing the full image, but on 1/2 the screen gradually filling into the whole screen). The picture is a bit distorted. Looked like a smile towards the bottom of the screen. After 5 minutes or so, the picture filled in completely and everything was OK until today’s changes.
2) Now, in addition to what I described above, the picture just became extremely magenta-ish in color. I can see the image completely and the TV is viewable, however it has an extreme magenta-ish hue. Also, it flickers quite a bit and there are greenish lines going across the tv. The picture is completely viewable with no distortion issues once the TV is warmed up. The indicator light above the power light on the TV blinks 5 times.
Any ideas on what might be wrong and how to fix it? I’m pretty handy, please let me know what components need to be replaced on how the repair should be completed. Also – Please provide me sources for the parts. I would appreciate any info regarding service manuals etc.
Thanks
Vinay
Posted on Sep 20, 2008
  • Sony Master
  • 8,617 Answers
You need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Posted on Sep 05, 2008
HELLO I HAVE A Sony Projection KP-51WS510 IT HAS HORIZONTAL LINES ALL OVER THE SCREEN WHAT CAN BE THE PROBLEM?
SORRY IF I GOT YOUR HOPES UP, I HAVE A KP51HW40 SONY WITH THE VERY SAME PROBLEM...FINE HORIZONTAL LINES COVERING ENTIRE SCREEN AREA TOP TO BOTTOM. I WAS HOPING MAYBE YOU HYEARD SOMETHING??? IF YOU DID PLEASE CONTACT ME AT BMER@CFL.RR.COM, I WOULD MUCH APRECIATE IT.
Nov 19, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 problem- 1. Picture is not stabilizing while can heard Audio clearly and continuous vertical moving picture. 2. How to connect TATA SKY INDIA DTH TO TV and convert PAL signal to NTSC or...
In your problem #1. try to do a fine tuning of the channel or adjust the horizontal adjustments. For the problem#2. Access the system setup of your television, from there you can choose either PAL signal or NTSC signal to operate in your system.
Oct 30, 2010 | Sony KP-51WS510 51" Rear Projection...
Need the code for the remote for a sony kp-51ws510
You need a Sony original remote--even a Sony universal will not access the menu.
With the Sony remote (Almost any Sony projection remote will work) you can adjust in the customer mode or enter the TECH menu for fine adjustment all over the screen.
If you get one and do not know how to enter the TECH menu--let me know and I will tell you how to do it and adjust there.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 19, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51 in. Rear Projection Keeps blinking 5 times. The red and green projectors are working fine, but the blue is not working. Sears service replaced the power supply, and the first board, then...
You may want to recheck your connections coming off the blue tube to the board. Also check the IC links/Pico fuses on the power board. I have a repair manual for this Tv if you need it. shanesebay304@yahoo.com
Dec 10, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP 51WS510 convergence problem
Please check pico fuses in D board and confirm +22 & -22 volt supply to convergence ICs.
Fuse numbers are as follows...
PS8001, PS8002, PS8003, PS8004, PS8005, PS8006
Dec 21, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 has a haze or back glow that cant be adjusted
It seems U are having no screen voltage.
U need to get it repaired
Rifaa
Nov 10, 2008 | Sony KP-51WS510 51" Rear Projection...
Rear projection out
See below exploded view of your Sony KP-51WS510 TV showing boards...
D board is Deflection Board and has convergence ICs qty 02. If tv has problem of convergence, either you need to replace complete board or replace defective parts ( STK ICs) check IC8001 & IC8002 in D board.
If you have electronics knowledge and experience of tv repair, you can make it.
Related service manual of product made things easy because of information, parts location, applied voltages, part numbers and descriptions etc.
Need further help, let me know to provide you more info.
Thank you.
Oct 07, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51 in. Dark picture
I finally heard from Sony tech assist. You have a bad high voltage transformer. As the set warms, the high voltage decreases and this is causing the problem. At this point, I would refer service to a local Sony authorized center.
Apr 18, 2008 | Sony KP-51WS510 51" Rear Projection...
PS3 to Sony KP-51WS510
To connect a PS3 for the best picture possibe is definitely HDMI. It carries both audio and video in the highest quality possible.
Apr 17, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp-51ws510 51" rear
The picture tubes are on there way out. turning down the screen control inside the tv sometimes gets a little more time out of it
Feb 16, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
183 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
