Question about GE JVM1850 1000 Watts Microwave Oven
Replaced key panel for F3 fault, still not working
I read on a previous post that F3 fault is a key panel fault.  Ordered a new key panel from GE, installed it today, but I still have the F3 fault.  When I turn on the breaker, the entire display lights for a short period of time, then it says "press clockkk", but nothing I press works.  Then, after another minute or so, it gives three loud, long beeps.  Any ideas on what I need to do now?  Thanks for any help you can give.
  • GE Master
  • 9,098 Answers
This answer assumes that the new keypad is the right one and that it is plugged in correctly.
F3 is normally a bad keypad, but it may be debris or residue on the circuit board in the area that the keypad plugs into, or there may be some corrosion on the connections of the keypad connector.
Look for whitish or dark green deposits on the circuit board. These may be mineral deposits or tarnished copper due to moisture.
These are most common if one cooks on the stove top without turning on the hood vent exhaust fan.
Feel free to post a good close up photo or two of any area you suspect.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 06, 2008
We are getting an F3 message on GE JVM1750DM microwave. After turning off power and then back on. It works for a few minutes, but then the F3 message come back ?
Hi
F3 error in your GE microwave means that the keypad/touchpad is bad and should be replaced. However, before replacing it you can follow these step by step instructions to clean the touchpad assembly and see if it works:
1) Unplug microwave
2) Remove two small screws from upper face plate
3) Remove screw on upper side of control panel
4) Life panel and pull out
5) Identify flat tape-like harness connecting circuit card to keypad
6) Wipe down harness with an all-purpose wipe
7) Use hairdryer to dry remaining leftover moisture
8) After this put the keypad back if its not solved then replace it.
Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | GE Microwave Ovens
Getting F3 fault. replaced smart board but did not help. Touch panel?
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jul 22, 2011 | GE XL1800 1100 Watts Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
Read-out shows F3
On a GE microwave, "F3" means a bad membrane keypad.
You can order a membrane keypad here and install it yourself according to this handy illustrated guide, or we can install it for you.
If the keypad is not available separately, you can order a control panel frame assembly here, which comes with a new keypad already installed.
But since this was posted under Jenn-Air, that confuses the issue. If yours is a Jenn-Sir, please post a new help request here on FixYa and include the full model number from the tag, or contact us for a free estimate and tips.
Aug 18, 2010 | Jenn-Air Microwave Ovens
F3 error code ge microwave
No, unfortunately the membrane keypad is not available as a separate part on this model.
You would have to order the control panel frame, which comes with a new keypad already installed.
The part number is WB07X10883 and you can get it for $86.82 here.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Nov 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
May 29, 2006 | GE JVM1861SF Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
119 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
