Question about Mitsubishi WS-55807 TV
No Signal I connected the cable to Ant-A but am getting no signal just static, PIP gets a very weak signal on Ant-A. It won't store channels in memory. DVD works on Input-1 but no signal from cable on Ant-A or Ant-B?
I connected the cable to Ant-A, then connected a short cable from the out loop to Ant-B. Works fine. Didn't have a manual, had no idea.
Posted on Sep 06, 2008
Tv signal problem
You may have to do a channel search to locate and store active channels in your area.
Jan 09, 2014 | Samsung LA40R81BDX 40 in. LCD TV
When I tried this out in the store, it picked up Al Jazerra, which is a cable channel and a couple of other cable channels but no DTV over the air channels. I purchased it since the store said they had...
Having weak signal are the most usual cause of not having it memorize in your flat panel TV channel when you re-scan to tune your flat panel TV. You will need a strong antenna receiver if you are trying to received a terrestrial channels. If still you got weak signal, you will opt to use an antenna booster, you need to get assistance from TV technician about doing this. Changing flat panel TV will not help, until unless the TV is equipped with strong tuner receivers (boosted type)
Jul 02, 2011 | Televison & Video
Cable company switched to digital, now my Ant A port on the vs-50603 does not receive signals. I can somewhat view the analog signals through my PIP only. other tv's in the house came back with signal 5...
When the cable company offers you digital cable, you typically need a cable box to unscramble the digital channels. Therefore you need to connect either a coaxial cable from the cable box's RF output, if it has one, or connect 3 RCA cables from the yellow, white and red jacks on the rear panel of the cable box to the TV. Analog channels only (if available) will go straight thru over the coaxial RF hookup. They are not scrambled. Select the proper input source on the TV for the cable box.
Aug 26, 2010 | Mitsubishi VS-50603 50" Rear Projection...
Euro vox max v full signal but no channels
make sure your boost signal is OFF its someware in ya settings i had this problem
Mar 24, 2010 | Audio Players & Recorders
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
We are getting a weak signal, no picture.
Make sure that at the box you are connecting the antenna in the right "Ant" connector at the converter and using the other connector to jump to your TV set "antenna in" connector, and have your set tuned in channel 3 or channel 4 (try both, just in case).
Another thing you may want to check is that your TV is set to receive channels "From the Air" not "cable". use you TV menu selections to find this setting.
You may also choose to connect the signal transfer from the converter to the TV using a 3 cable set of Audio (red and white RCA connectors) and a video cable (yellow connector) and setting your TV to get the "signal input" from the right input selection, (it could be labeled as Front, or Video or Aux) in this way you will get a even better image quality.
Then press "menu" on your Digital TV converter remote, then if and when you can see the menu in your TV, look and go for auto setup so the converter can look and find all the available channels in your area.
If there is nothing broken you should be able to get you Digital programming right there.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
That sounds about right if you have cable instead of an antenna cable. If it can't tune anything but 5 channels in, that's all it claims; set it to CABLE IN instead and try that so the tuner can get along with your cable box. If you really do have an antenna hooked up, get it away from whatever's reflecting signal and screwing up reception.
Sep 12, 2008 | RCA DRC8030N
Proscan PS50700
Appreciate the direct "Ask Me".
Technically, when a TV signal is said to be snowy, it indicates that the incoming RF signal is weak; on the other hand, when a TV signal has static, this refers to electrical noise that goes with the TV signal.
Having said that, then to your concern:
  • for snowy signal, it is the cable providers problem. They have to change where your incoming cable is tapped from, check/replace the feedin cable itself or worst case scenario, replace the line amp/distribution amplifier feeding your cable input;
  • for static noise, what is required is to check possible sources which could include (but not be limited to) electronic ballasts of florescent lamps, electric fans, hair dryers, shavers, wireless phones, computers and others.
Additionally, you may want to check if you have any RF producing devices attached to the TV such as VCRs, DVDs, game consoles. You can try unplugging them when not in use.
Worst case scenario is the tuner block of the TV is getting weak (unlikely but possibly). You can try rewiring the cable to feed first into a VCR, connect the VCR to any of the free Video IN, and select channels through the VCR. If significant improvement, then you have just confirmed an internal fault with the TV tuner, if problem persists, then the static/noise/low RF is caused by something else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 31, 2008 | Samsung TXE2745 TV
Mitsubishi WS-55807 TV Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
