Question about Cameras
Camera Canon Power shot SD800 IS, LCD screen shows much speckling. Also in telphoto mode the pictures are grainy.
  • carylschaefe Sep 05, 2008
    I don't think the LCD screen (speckling) is part of a reset problem.  I think it is a product of aging our use.  Is this a situation of replacement of the LCD screen? I use the term speckling to indicate a modeling effect seen in the screen. It has lost it's clear brilliance it once had.  The camera is about 2.5 years old.  Generally, it takes good pictures.
    I have noticed at times the telephoto pictures show grain. I have reset the camera and will try more pictures with various settings.
    I believe the replacement of the LCD screen may be the answer
    Thanks for giving me repairable options.
  • 13,433 Answers
Try restoring your camera to the default settings, in most cameras theres a option for this in the menu, or there may be a reset button to press to get it to reset everything back to factory defaults.
lets see how the things are after this
Posted on Sep 05, 2008
  • Ekse Sep 05, 2008
    If the problem only shows up on the screen then it would be the screen. I got you a replacement lcd assembly, see here
    click here, ebay item link
No image on screen when switched on. New batteries fitted. Canon Power Shot A60.
If your Canon A60 camera shows previously saved pictures in memory card in playback mode but does not show live view in camera mode than ccd imager chip in camera got defective and will be replaced.
Canon offers free of cost ccd imager chip replacement. Click Canon CCD Imager Advisory to avail that FOC service.
Thanks.
Jun 21, 2010 | Canon PowerShot A60 Digital Camera
Lcd screen flickers in photo mode
If your Canon A85 shows distorted image in live view (camera mode) then its known problem of ccd imager chip failure. Check below image.
canon offers free of cost ccd imager chip replacement in A85 model.
Please confirm if its canon A85 camera or any other model to provide you more info.
Dec 23, 2009 | Canon PowerShot A85 Digital Camera
LCD screen not showing picture to take.
Could be ccd problem. These were common with this type of Canon camera. Download Canon pdf file re these faults.
Jun 28, 2009 | Canon PowerShot A560 Digital Camera
Canon A60: Grainy pictures, jumpy lcd screen image
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jun 09, 2009 | Canon PowerShot A60 Digital Camera
Blank View Screen
Press DISP. button, and repeat untill the display shows up
Jun 02, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Grainy LCD display
Are you in night mode? Sounds like you are in a high gain setting, like ISO 3200 or night mode.
Jul 17, 2008 | Canon PowerShot SD1000 Digital Camera
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
Fuzzy, Grainy Pictures
This camera is a perfect one to show the problem with the tiny sensors in the typical point and shoot. From the same sensor size that previously gave 2 or 3 megapixels, Canon now extracts 7.something. In order to do that, they have to turn the gain up so that each pixel actually puts out a signal to be recorded. The natural outcome of that is noise. In this camera, Canon includes heavy noise reduction software that softens the image in order to reduce noise at the various ISO settings above the minimum one, but the result is still a mix of noisy and soft or fuzzy images.
However, the noise should be well controlled at the low end of the ISO settings.
I suspect you have somehow gotten the ISO setting set up higher than the lowest one. Use the four-way controller to access the ISO and set it to the lowest (80) value. This should give you noise free shots.
As an additional suggestion, read the concise review of this camera at Dpreview, the link for which I've provided.
http://www.dpreview.com/reviews/CanonSD800is/
If you have any questions, please let me know before giving this answer a rating and I will provide it. Thanks.
Feb 06, 2008 | Canon PowerShot SD800 IS / IXUS 850 IS...
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Cameras Logo
51 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
