Question about GE JE2160 Microwave Oven
I have display, but no lights, no fan, no power!
I found the envelope inside unit and tried to follow the diagnostic flow chart but it's not very good / helpful. Or maybe I just don't know what the heck I'm doing. Can set cooking time and when I press start, the microwave clicks like it is going to start heating, but I get no lights, no fan and no power, but the timer continues to countdown.
The only weird thing that happens is if I push one of the food heating buttons (popcorn, potato...etc) and then push start, I get a "sensor error". Since I've never used those buttons before, I don't know if it was supposed to start cooking directly after pushing "popcorn" or if I was supposed to hit start. Either way, it probably shouldn't give me a "sensor error".
Any help is appreciated!
Thanks,
-Bryan
  • 1 more comment
  • bcobb Sep 05, 2008
    More info: Just found the manual for a GE JEM31 (I think) and it does say that you will get the "Sensor Error" if you open the door after pressing Popcorn. So maybe you also get "Sensor Error" pressing Start after pressing Popcorn.
  • bcobb Sep 20, 2008
    Thank you SO much for the response. Since I did get the microwave to actually work again and then now it's not. It probably is the door switch. I'll look to see if it's loose and then test continuity. Thanks again for your response. You all rock!
    -Bryan
  • bcobb Sep 26, 2008
    Microwavesvc,
    After testing my door switches, I have determined that at least one of them are faulty so I would list to replace them all as microwavedisplay.com says. I have a total of 4 switches, an upper door switch, a lower door switch and then I have two switches below which are activated by the door opening latch/button (I'm assuming these are the "monitor" and "door sensing" switches?
    I'm assuming I should replace all 4?
    Thanks in advance!
    -Bryan
  • GE Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Glad you found the "mini-manual". It's very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 06, 2008
  • William Miller
    William Miller Sep 26, 2008
    The door sensing and monitor switch in today's microwaves usually do not handle a lot of current, so replacing the primary and secondary interlock switches is normally fine.
    Some may have one primary switch and the secondary is a relay, or vice-versa.
    Thanks for the FixYa, happy to help.
NN-T945SFX CODE H98 RUNS A FEW SECONDS THEN STOPS
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Dec 24, 2014 | Panasonic Pansonic microwave
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
Popcorn popper 50030178 I found this old popper like my nanny used to use. But I don't know how much popcorn or oil to use can you help me. I have the measuring cup lid all the parts with it.
What type of popper is it? The 50030178 model isn't one I'm familiar with.
For most of the small air poppers, such as the Presto Air poppers, fill the measuring cup lid with popcorn so that the popcorn is level with the top of the cup. Add this amount of popcorn to the popper. On those units, there is a fill line inside the popping chamber. Do not fill past the line. For these air poppers, if you want to have butter or margarine on the popcorn, add 3 tablespoons of the extra to the lid after you replace it on the popper.
For the Hamilton Beach Hot Oil Poppers, the manual for the 73300 is available here: http://www.hamiltonbeach.com/use-and-care/use-and-care.php . Fill in the type of device and then the model. The amount of oil and popcorn will depend on how much you want to make. For a single serving, you need 2 T (tablespoons) of kernels and 1 - 1 1/2 t (teaspoon) of oil. For enough popcorn for a family, you should use 1/2 cup of kernels and 1T of oil. http://useandcares.hamiltonbeach.com/files/840190701.pdf has a full chart of the amounts on page 6.
I hope this helps. Please add a comment with the brand of popper and I'll check for a specific chart for that unit.
(It's been a while since I used the air popper that I used to have.)
Jun 21, 2011 | Hamilton Beach Microwave Ovens
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
Display out on GE spacemaker JVM140 microwave
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You will have a fuse, plus one or more thermal cutouts or thermostats, any of which can interrupt power to the unit.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Depending on your full model number (you listed part of it) the small low voltage transformer is located either on the control circuit board, on a bracket attached to it, or on the chassis / floor of the microwave with wires running back to the board.
If it's a separate type, the mini manual will show you how to check the continuity of the windings. But generally the primary (110V side) will be the one to fail, and it should read somewhere between 100-300 ohms.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Apr 18, 2010 | General Electric Microwave Oven
I dont have and enlish manual. It shows two items inside called Tampas de Mica. Are these supposed to be there or should they be removed
I do not have an English manual, but maybe if you posted a brand name and model number I could try to find one for you.
"Tampas de mica" in Portuguese translates to "mica cover". If these coverings are inside the oven cavity they are supposed to be there. Mica is a dielectric material that resists the flow of current. In a nut shell, they act as insulators to reflect RF energy inside the oven.
If you have questions, please let me know. I hope you find this information helpful.
Aug 14, 2009 | Microwave Ovens
GE profile 1800 2yrs old. Model #JVM 1870cf06. No heat,
{ MAGNETRON FAILURE }
I cut the magnetron right down the center. I can see why so many GE magnetron fail. They have a poor Filament design. The sparial spring that completes the filmanet circuit on the cathode will become brittle over time and will surely fail. I am a layman when it comes to this design. I see no GE
magnetron with this filament design lasting 10 years.
May 27, 2009 | GE JVM1440 Microwave Oven
It s not working at all.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Please reply back with your brand and model number so we can help you.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Nov 21, 2008 | Microwave Ovens
Same problem- microwave shuts off
You have a bad magnetron. The fact that it works when the board is tilted is the giveaway.
If you don't want to pay for the service call and prefer to do it yourself, please note the safety and parts links below:
We have *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE JE2160 Microwave Oven Logo
148 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
