Question about Smeg F170 Pyrolytic Stainless Steel Electric Single Oven
Whirlpool Datid OV D10
Hi  I need to fix the clock of the given model in Whirlpool ovens (Whirlpool Datid OV D10) I got the clock but doesnt seem to  understand the ciruit and connections. Pleae help!
  • nurdcost Sep 05, 2008
    Thanks for the reply.
    Here are the details of the problem.
    The oven doesnt get started, I tried some tests and the clock turned out to be the problem. I ordered for the new clock and fixed it with exact connection.
    The model number is not knon but he side bar (behind the oven door) gives 90048856. When I searched I dont find this model number any where. I went to Ikea and found the model to be Whirlpool Datid OV D10.
    Can you please help?
    Thanks.
    Thanks so much for the help the clock is analog clock that I bought and it has 4 connections. I tried to replace the wires as they were but of now use. I will look for the circuit board once again and see if your suggestion help.
    Thanks again.
I have an ov b 10 whirlpool/ikea oven that i have cleaned the thermostat knob numbers off. can i buy another set of numbers because my guess work is ruining my food!
thanks
Posted on Feb 23, 2011
  • 116 Answers
Its difficult to say where to start as you did not indicate what was the matter with the ovenin the first place.That plus the model number would help
Regards
Posted on Sep 05, 2008
  • D Clare Sep 05, 2008
    Hey Nordcost
    I do not know which type controller (clock) you have bought - but if you could describe it maybe I could help more - but - try to identify the following.
    L1, L2, N - This is where the main supply is connected to the circuit.(most times the white one is neutral (N) These are usually near each other - Usually "stab on" (spade end) connectors
    bake, broil - These are usually near the relays (sometimes written there too) on the circuit board also usually "stab on" connectors
    The other connectors include the temperature sensor is usually a quick connector (plastic connector) with pins you should be able to identify by counting the pins in them
    Hope that helps
On a whirlpool double oven what does F2 error mean and canit be fixed
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. If present, replace control board (clock). For SELF CLEAN models, check door lock operation. Check sensor, sensor harness, and the sensor harness connection at sensor and oven control. Also check for any causes of high resistance in the oven temperature sensor circuit. Remember: The oven control board (clock) measures resistance of sensor circuit, not actual oven temperature.
Nov 23, 2016 | Whirlpool Ovens
Why is my oven not heating? The light and fan are working, but the grill and oven are not heating at all.
Is there any customer care number, in the booklet?
If it isn't try a Google search, type the brand and model and search for the manufacturer.
Find a customer care number and call them.
OR
If you can find any electrical technician from near by he can also help.
Jun 14, 2015 | Ovens
Whirlpool oven model RBD245PDQ15
Replace the display/control pt # W10340941, it can be purchased at www.repairclinic.com or www.apdepot.com
Apr 24, 2012 | Whirlpool Ovens
The grill works but the fan over does not. What do I need to do to fix it?
Hi Your clock timer is probably on automatic try resetting the clock If it is on auto you will have a auto light up somewhere in the display
May 27, 2011 | Whirlpool AKZ159IX Oven
Have a whirlpool stove model # wbp88800. There is
F8Board failureReplace control board (also called ERC or clock).
May 14, 2011 | Whirlpool Ovens
E6 F2 - Works sometimes, then will go out. Light will always work but clock and ovens will not. Whirlpool double oven= I don't know where to find what model it is.
Hi, to fix this error code follow the instruction below...
  • Check keypad connector for firm connection (keypad connects to control board).
  • Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 06, 2010 | Ovens
The digital and analog timer do not work
No, there is not a fuse on this model. You will need to repalce the clock assembly for this unit. Call us asap and we'll ship the correct part out to you asap so you can start cooking again. We look forward to working with you!
Oct 17, 2009 | Viking DEDO205 Stainless Steel Electric...
Smeg F170 Pyrolytic Stainless Steel Electric Single Oven Logo
1,841 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
