Question about SanDisk Sansa e260 MP3 Player
'Hold' button problem
With my hold switch toggled to off, once in a while the device will flicker between hold and un-hold. Like i said the hold switch is not engaged. I think it may be an internal hardware problem, where the switch is making some contact even when it is switched not to.
  • da_boi Oct 15, 2008
    that wasn't helpful at all...
    Sergeant:
    Champion:
  • 281 Answers
Open it and swtitch
Posted on Oct 13, 2008
How to activate touchpad on acer e1-571
Hi
One of the toggle switches using the FN key turns the touchpad on and off.
<Fn> + <F7> Touchpad toggle. Turns the built-in touchpad on
and off.
If you go here :-
Drivers and Manuals
and selecting your model from the selections offered ie "Notebook" then "Aspire" then "Aspire E1-571" you can find all the documentation, drivers, applications, BIOS etc for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 16, 2014 | Acer Aspire Computers & Internet
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
How to turn on wifi? Its been 2 -3 days wifi isnot being loaded?
Press and Hold the FN function key then hit F2 while holding the FN Key down.
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
May 25, 2012 | ASUS Eee PC 1000HE Netbook
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
My ipod nano is frozin and i cant un frees it i tried evrey thange and it seas device not found.
Ok i have looked into the Issue you are having and concluded that the most likely solution is to reset the device, to do so follow these steps:
1: Place the device on a flat, level surface 2: Toggle the Lock/Hold switch to the LOCK position, then place it in the UNLOCK position 3: Finally, press and hold both the Play/Pause and the Menu buttons AT THE SAME TIME until the Apple logo appears onscreen
Aug 20, 2010 | Apple iPod nano
My 3rd gen nano will not show up on itune but it shows on my computer
reset it then plug it in it usually work for me to reset there are 2 ways
1) toggle "hold" switch on off three times making sure hold switch is off the press n hold down menu and center button from 3 to 10 seconds or untill apple logo appears
2) same as above but without toggling hold switch
press and hold menu and center button till apple logo ppears then plug in cable to ipod and then in to ur computer
Apr 08, 2010 | Apple iPod nano
Ipod froze request me to go to www.apple.com/support/ipod
There are three reset variations for ipod's, depending on how old they are:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds.
Or:
  2. Press and hold the Menu and Middle buttons until the Apple logo appears, about 6 to 10 seconds.
Or:
  2. Press and hold the Play/Pause and Menu buttons until the Apple/iPod logo appears, about 6 to 10 seconds.
I hope that helps.
Dec 30, 2009 | Apple Audio Players & Recorders
My ipod chromatic is completly frozen.
You are doing the reset wrong. Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 07, 2009 | Apple iPod nano MP3 Player
Load main image failed switch to recovery mode
follow the above steps but turn on the power button if nothing is happening. It's the only way I got my e280 to recovery mode
Sep 23, 2008 | SanDisk Sansa E280 MP3 Player
Ipod always on hold
My 2 GB nano shows the lock icon no matter how many times I toggle the hold switch on and off and press the Menu/Select buttons. I've recharged and restored it any number of times with no luck. Computer recognizes it when I plug it in but once I unplug it, none of the buttons work. When it's plugged in and fully updated, it shows the languages menu. I'll be eternally grateful to anyone who can offer any assistance!
Dec 23, 2007 | Apple iPod nano
SanDisk Sansa e260 MP3 Player Logo
122 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
