Network I have a PC labtop. I have lost my network connection. I use wirless 2wire. I do not know what is missing
    Problem Solver:
  • 12 Answers
1.Press Start, select control panel.
2.Double click network connection.
3.Right click your wireless connection and select enable.
Hope this help Thanks Let us know. Obed
Posted on Sep 05, 2008
I would like to know how to connect to my wireless from my laptop.
Get a wirless print server, this will attach to your printer and your labtop will detected your printer as a wirless device. if you don't know what that is ask someone at walmart. Its cheep and easy to set up.
Jan 01, 2013 | Office Equipment & Supplies
My laptop wont connect to my wireless router, but my desktop which is directly connect will?
You wirless switch has to be turned on for that to work. If that is not the issue then sometimes it it best to plug it in to the router and set it up that way. the computer already recognizes the computer and it finds it easier to set up the wirless.
If you want to make it real easy to manage your computers and the internet. Download a network manage ment program. I will help you connect you computers to the internet and much more. Network Magic Pro or Network Magic Essentials $30-$50.
I hope i have given you information that has helped you.
Thank you for the chance to help as well...
Randy
FixYa Support Expert
Nov 05, 2009 | Linksys WRT160N Wireless Router
Cant connect to linksys
try goin in to the settings for the router it self. ip addres 192.168.0.1 make sure you got the right security key.
Jun 28, 2009 | Linksys Wireless-G WRT54G Router
Getting new labtop
The desktop should have an eathernet port on the back if it does you will need to get an eathernet cable from your loca computer supply store. This cble will be pluged into that port and into one of the eaternet plugs on the router. To conect the laptop there should be a wirless icon on the lowere left side of your screen on the taskbar it may need to be expanded by pushing the arow. You will the right click on that icon and say view wirless networks. It should pop up a list of networks click on the one you own and say conect. It might ask for a WEP password which should be located on the botom of the router or the side. I hope this helps you and look forward on helping you again.
Jan 28, 2009 | 2wire (1000-400108-001) Router
I had my DSL disconnected. I am using cable internet w/Comcast. I've DIR-628 connected to Mot-SB5101 Cable Modem. This setup is working fine. However I'd like to use my old DSL/Router 2wire 2701 to connect...
First you should see a wirless icon on the botom left of your screen wich is on the task bar. The say view wirless networks or what ever it would say then you should see a list of avalible networks at that time. The slect the network that you own an say conect. When conecting it way ask for a WEP password which is located on the router. I hope this will help you.
Jan 14, 2009 | 2wire HomePortal® 1800HW Router...
No wireless connection
try 2 disconnect and reconnect the adapter, turn off the router and power it back again,set the wirless channel to 9 r 11 it will work
Nov 03, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Red light
Can any computer connect to the internet?
You said you connected the computer with the cable to the 2wire using an ethernet cord, did it go to the internet?
Do you have a modem connected with the 2wire? (not a computer modem)
Do you have the DSL package or Cable package from Time Warner?
Aug 24, 2008 | 2wire 1800HG Router (RG1800HG00)
2wire 1701 HG Gateway wireless not working
There could be a lot of possibilities why you lost your connections at the same time. Could be windows update or changes had been made in your 2wire 2701 HG.Its impossible to say that your wireless adapters turned bad all at the same time.As what you observed , wireless light is off meaning your 2wire doesnt detect any wireless connection. You can try reconnecting them 1 at a time by going to your wireless connection tool or network connections.
If that didnt help, you can use your PC w/c is connected using the USB connection. Using this step, you 'l have a chance to edit and view your wireless network. For you to access your 2wire you must know what your 2wire address {default gateway}. Using your hardwired pc go to start > run > type in cmd then hit enter > on the Dos command screen type in ipconfig and hit enter> youl see your default gateway . It would look like this 192.168.1.254 for example cos sometimes it would vary depending what ISP you have, Open your fav browser and on your address bar type in your default gateway. That would lead you to your 2wire page, there youl have a chnace to view you home network. Check if your wireless encryption and you network name if everything is still the same. {Best thing is to change your wireless name or SSID. Then try to reconnect on your wireless connection for each computer and make sure you have your wireless encryption.
Hope that helps. Pls let me know asap if you need clarifications.
Cheers.
Jun 15, 2008 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
