Question about Dell Computers & Internet
My friend computer power lights does not come on
Dell computer
  • 1 more comment
  • samuelbarnet Sep 05, 2008
    No changes have been made.
    He said that he download some material and was in the process of printing it.
    The computer just went off,and stays off
    No nothing is changed in the case
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    have you/he recently changed anything in the case? or installed new hardware?
  • 236 Answers
Make sure to check all connections to the computer from the wall/power supply, and make sure if he has a surge protector, that he did not accidently turn it off. If everything is connected ok, check to make sure the switch on the back of the power supply has not been turned off (if the power supply has one).. Also make sure that none of the buttons on the front of the PC are stuck in.
If all is good, the power supply might have failed, in that case, try changing the power supply with a new one.
Posted on Sep 05, 2008
  • Dave MacPhee
    Dave MacPhee Sep 05, 2008
    You could also try pluging the system into another wall outlet or change the power cord, just in case a surge happened.
Why thin pink line on the monitor display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
8. If the same pink line shows when you hook it to another computer, it's a problem with the monitor.
Jul 22, 2014 | Dell ST2010 20 inch LCD Monitor
Hello, I use pc computer and my monitor is of dell IN1920B but I have a problem that its display goes off while working but power light is on and media player and other program still gets running.
Good luck.
Jul 05, 2014 | Computers & Internet
Dell monitor E173FP power led flashing green, no video
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Mar 07, 2014 | Dell E173FP 17" LCD Monitor
My dell desk top wont power on when.i try to turn.it.on
When you press the power button and if the power LED does not light up then you most likely have a faulty switch mode power supply.
If you do not know how to fix it then I suggest you as a tech savy friend to help you or take it to your friendly computer repair shop.
Apr 13, 2012 | Dell Computers & Internet
My Dell XPS 420 will not turn on. Power light shows a steady blue color. No diagnostic lights show up.
The RAM maybe faulty.
Try resetting the RAM modules to make sure it is seated correctly in the memory slot.
If the computer still does not boot up then the RAM maybe faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them tested. If faulty then replace the RAM.
Feb 25, 2012 | Dell XPS 420 PC Desktop
Dell D810 Laptop wont power on. Have brought 2 new ac power adapters. They work (led light on power adaper goes on), but when I plug them into the computer the led light on the adapters go off. Computer...
HELLO FRIEND, THE PROBLEM WITH THE LAPTOP IS QUIT A MINOR ISSUE BUT YOU HAVE TO DO SOME SOLDERING WORK ON THE COMPUTER. THERE'S A POWER SUNG ON THE COMPUTER WHICH HAS TO BE SOLVED BEFORE IT CAN WORK WELL, AND STOP THE LIGHT OFF PROBLEM.
Jul 30, 2011 | Dell Latitude D810 Notebook
Friends computer just quit. Replaced power supply. No pwr up
Did you not wear an antistatic band? If not, you have killed your PC.
May 05, 2010 | Dell XPS 410 PC Desktop
Monitor not working after adding drivers
1. turn off your computer
2. turn off your monitor
3. Unhook the power and video cable from both
4. Reseat them both on both ends.
5. Turn on your monitor
6. Turn on your computer
If its still doesnt work after all 6 steps, your monitor is bad, sorry.
Apr 02, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Amber light on power button of Dell Dimension 4500
ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
Nov 30, 2008 | Dell Dimension 4500 PC Desktop
Computers & Internet Logo
44 people viewed this question
Alun Cox
