Question about Sharp Notevision XG-NV6XU Multimedia Projector
My Sharp Notevision was overheating after replacing the bulb. It would work fine for ten to fifteen minutes, then the lamp icon would blink in the bottom left corner of the screen before the unit shut itself off. Once cooled off, the unit would function normally for another ten to fifteen minutes. However, the last time I used the unit, a large round yellow stain spread across the screen. Can you help???
Kevin
    Genius:
  • 1,027 Answers
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
Posted on Sep 05, 2008
Yellow in center of picture
The blue device is dying allowing green to shine thru instead of white. Very common problem called color decay. Happens on average about evey3-4000 hours. I suggest next purchase a dlp product, they are immune to this problem. Good luck
Mar 29, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Missing blue region
It sounds like the bulb overheated at some point. Time to replace the bulb.
Oct 31, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Sharp Notevision 6 XG-NV6XU
Perhaps clean the side filter as well as per page E-46 in the manual on following link: http://www.fixya.com/support/t161763-sharp_notevision_6_xg_nv6xu You can find links to email support & FAQ's on this link: http://www.sharpusa.com/products/TypeManuals/0,1083,29,00.html
Jul 28, 2007 | Sharp Notevision XG-NV6XU Multimedia...
I have a sharp xg-nv5xb projector that wont power on.
bad power board or blown fuse. If you feel comfortable you can take the out case off and follow the power connector to the board. You can then check the fuse. Make sure the unit is unplugged before doing so. If the fuse is fine then you will need to replace the board as it probably has a bad capacitor or resistor. You can find a power board online but to be honest, its probably not worth the money to by a new one. Would probably be cheaper to buy a used one with a bad lamp and cannibalize the power board out of it.
Mar 06, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
bgrenco@aol.com..
Jan 18, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Sharp notevision XG-MB70X
No special tools needed. these units (dlp projectors) are designed so the lamps and color wheels can be changed out by the user. Some can figure out how to do this easily without instructions but to be safe just do a quick search and find step by step instructions. You can also refer to your owner's manual.
Jul 17, 2008 | Sharp Notevision XG-NV6XU Multimedia...
Having problems with my sharp notevision XG-C40XE
Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
Aug 23, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Sharp Notevision 6 XG-NV6xU
reset the lamp hours on your projector
Sharp Notevision XG-NV6XU Multimedia Projector Logo
230 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
