Question about PNY Verto GeForce FX 5200, Graphic Card
Monitor how do i use the dvi-/hdmi, do not work with my video card? . have hdmi to dvi plug on my video card.
    President:
  • 1,179 Answers
I don't think the FX 5200 supports DVI. If I remember right this card only supports VGA. Hope this helps.
Posted on Dec 20, 2008
I figure I need a replacement graphics card. The PC worked fine yesterday. Turned it on today and no signal to monitor. Tried both DVI and HDMI with the same result. Monitor is Gateway LP2417.
try pulling the power cord out of the monitor and then wait 30 seconds and pull it back in to monitor . Are you dealing with a graphics card or a motherboard video chip. May have DVI and HDMI plugged into motherboard rather than PCI video card. Check Bios to see if conflict exists between motherboard video chip and PCI video card.
Dec 31, 2015 | Gateway GM5632E 2.4ghz Core 2 Quad 3GB Ram...
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
I want to connect my Xbox 360 to my aoc f22+ monitor so I bought a hdmi to d-sub cable to plug the Xbox into the monitor as it didn't have a hdmi input. The screen just shows a blank image and the only...
You need a HDMI to DI cable not HDMI to d-sub cable. The sellers that are selling that cable do not tell you that it will only work with special video cards that output analog to the HDMI connector. HDMI is digital and so is DVI so they will adapt to each other. Keep in mind that this is for video only, sound will not work on the monitor because the DVI port does not support sound. You will need to add a set of speakers to the Xbox
Aug 27, 2012 | Computers & Internet
Hi - I have a shuttle xpc sxh57 core i7 model. A couple of days ago - it stopped sending a dvi signal to the monitors. I have replaced the video card, tried clearing the CMOS and cleaned dust. The fans and...
I suggest try the HDMI connection on your machine and see if its able to give display, since you purchase a new Video Card I assume it have a HDMI port. Or try different monitor with a DVI port if you really want a DVI connection, If it works it means the DVI port on your monitor is faulty.
Hope it helps.
Apr 20, 2011 | Shuttle Computers & Internet
I run a PC with the newest sandy bridge hardware and a Msi GTx 560 Twin Frozr II video card (dual Dvi-I input and a mini-hdmi input). I also have a BenQ G2222 monitor (one VGA input and one DVI-D input),...
The problem might be with your ram. Try taking it out and putting it back in. You might also have a problem with the video card. Make sure it is secure and screwed in.
Mar 19, 2011 | Computers & Internet
Well i thinking about hooking my t.v. to computer with out unhooking computer screen. i need to know were to plug in the t.v.
This will only work if you have a graphics card with two outputs; if you do, they will be right next to eachother, and will be a s-video (small round) VGA (blue) DVI (white) or HDMI (trapezoid).
Mar 02, 2011 | Computers & Internet
Clicking noises coming from monitor with hdmi cable attached to computer have no problems with other connections that came with monitor
Try getting a video card, if not look for a new monitor.
Reason i say get a video card your motherboard is probably working to hard depending on how old your pc is. When getting the video card it takes stress off the board when monitor is plugged into video card.
Apr 21, 2009 | Computers & Internet
PNY Verto GeForce FX 5200, Graphic Card Logo
82 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
