Question about T-Mobile Cell Phones
My sim card is locked ive turned it off at school and it wont allow the simm pin to open access
    Brigadier General:
  • 7,752 Answers
It would be best to take the phone to T-mobile store and have the help team correct it for you
Posted on Sep 05, 2008
Phone says there is no sim card but its installed.
SIMM card could have dirty contacts, pull out the card and clean the contacts with a pencil eraser used gently and a clean cloth, reinstall. SIMM card could also be from a different carrier than the phone was originally designed for (phone is locked).
May 02, 2015 | Motorola Mobility DROID RAZR MAXX HD
Confimed sim pin password puk pin came up unexpectectly on phone can not use phone until i come up with a pin i have no pin
Hi the PUK code is the security code for the sim card and not any code to do with the phone, all you need to do to get the PUK code is call your service provider.
your service provider wont charge for giving you the code as the code belongs to you, all you need to tell them is your phone number or if you dont know that then the number printed on the sim card, they will then provide you with the 10digit PUK code for free over the phone.
this will then allow you to access the sim card.
The only place you can get the PUK code from is your service provider as their is no where else that keeps these codes, if you still have the card the sim card was attatched to then it will be written on their but if you no longer have this then the only way your going to get the code is by calling your service provider, they wont charge you for this as the code belongs to you,
you do have another option open to you though, if you dont need that sim card then you can go out and get another sim card and when you get given a new sim card you will get given the unique PUK code it will be written on the card the sim card is attatched to.
let me know if you need further assistance ok.
plz rate this solution as i have a whole page of unrated posts, thanks
Nov 29, 2010 | Cell Phones
How do you open the case to install RAM?
Instructional steps
  • RAM
  1. Determine what kind of RAM you need, and whether your computer has enough open slots to hold it. The new RAM should match the existing RAM's specifications and configuration.
  2. Shut down the computer and leave it plugged into the surge suppressor.
  3. install-ram-1.3-120x120.jpg Disconnect all peripheral devices, such as the monitor, from the computer.
  4. install-ram-1.4-120x120.jpg Remove the computer cover.
  5. Ground yourself to the computer with professional grounding equipment like an anti-static wristband or hold a metal part of the chassis.
  6. Remove any cards or internal components necessary to give yourself unobstructed access to RAM sockets.
  7. install-ram-1.7-120x120.jpg Pick up your SIMM (single in-line memory module) or DIMM (dual in-line memory module) by the ends without touching pins or chips.
  8. install-ram-1.8-120x120.jpg If adding a SIMM, find the notched end and turn the SIMM so that it is parallel to the existing RAM card(s). Insert the SIMM into the socket at a 30-degree angle. If adding a DIMM, insert the DIMM straight in so that it is perpendicular to the motherboard.
  9. Use slight pressure to keep a SIMM from backing out while rotating the module to an upright position perpendicular to the motherboard.
  10. Make sure the small holes on each side of a SIMM fit into holders
  11. install-ram-1.11-120x120.jpg Feel or hear retaining clips lock a SIMM into the socket; close the side clips on a DIMM.
  12. 1 Gently try to pull the module out to ensure it is locked in position.
  13. Replace all internal components.
  14. Leave the cover off and reconnect the monitor, keyboard and mouse.
  15. Turn on the computer.
  16. Check the amount of RAM by right-clicking the My Computer icon in Windows and choosing Properties. On a Mac, use the About this Macintosh command in the Apple menu.
  17. If you don't see the right amount of RAM, turn off the computer and try "reseating" the SIMM or DIMM (take it out and put is back in) and reboot. If that doesn't work, call a technician.
  18. Shut down the computer and disconnect the peripherals again.
  19. install-ram-1.19-120x120.jpg Replace the cover and reconnect all the peripherals.
Oct 06, 2010 | Apple 24" iMac Desktop
How i will initialize my SIM card?Should i enter my SIM PIN number?
Hi
Remove the battery from your phone. Slide off the back cover of your phone to get to the battery. Gently lift the battery from its compartment to remove.
Insert the SIM card into your phone. Once your battery is removed, insert the SIM card into your phone. Look at the image on the phone to see how to insert the SIM card correctly. Make sure it is pushed all the way into place.
Replace the battery and turn on the phone. Replace the battery back into its compartment and replace the back cover. Turn on your Nokia 2610 phone, and it should boot up. The name of your wireless provider will appear when your phone is turned on.
Allow time for your phone to read the SIM card. Once your phone is booted up, it will say initializing. This means that it is reading your SIM card information. Once your SIM card is read, your phone will go to the home screen. Your SIM card is now activated, and you should be able to access all of your information.
Please accept the solution if it's helpful. Do get back to us for any further query.
Sep 20, 2010 | HP iPAQ h6315/h6365 Pocket PC
Puk code
PUK- stands for PIN UNBLOCKING KEY.. well this happen only when u enter an invalid passcode when u enable a password protection for ur sim card. this is different when u miss entering codes on your phone lock. note: "sim locks", and "phone locks" are different from each other. sim locks only allows u 3 tries and after that a PUK will be required. while phone locks dont have any limit. so if thats the case.. ur only hope is the manual that comes with your sim cad. in there u can access for ur PUK and after entering that successfully u can now access ur sim card. but if not, u have to buy another sim card or change another number. but u can still use your phone.. -jepoyPH
Aug 16, 2009 | Cell Phones
I saw your reply phone lock
Your pin number is probably your sim code!
Check PUK
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Are you sure it’s the Master code you need. Which is the one that you want?
Special Code/Service Provider Lock Code:
This code is required to allow a phone locked to a particular network's SIM cards to be used with a SIM card from another network. Orange and T-mobile lock handsets in this way, though O2 and Vodafone are beginning to lock PAYG and WAP handsets. The unlock code varies from individual handset to handset.
Blacklisting:
This is not a security code, but it works like one! To help combat mobile phone thefts, the networks share a database of the IMEI (International Mobile Equipment Identity) of mobile phones that have been reported stolen. Once a phone is on this list, it will not be allowed to use any of the networks.
This can be a risk if you buy a second-hand phone, because if it has been stolen, or if an unscrupulous seller makes an insurance claim after selling, the phone you bought in good faith may be permanently disabled.
Be very careful to check the source of a second-hand phone!
Voicemail Pin:
This is a code that you choose to secure the voicemail/answer phone service on your mobile phone account.
If you do not set a voicemail PIN, you may not be able to access voicemail from anywhere but your own mobile phone. In some cases, leaving the voicemail PIN at the default can let other people listen to or delete messages left for you. There may be a default code (3333 on Vodafone), but you should change it straight away!
Jun 29, 2008 | Sony Ericsson W200i Cellular Phone
I locked my sim
check with costomer care
Jun 12, 2008 | Samsung SGH-x427m
I forgot my lock code i tried my old lock code but i wont open, so i turn it off. after a few minutes i opened it again i enter my lock code again but still it wont open, what do u think should i do???
SIM pin code:
"One day, I'm going to procrastinate..."
May 04, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
