Question about Konica Minolta DiMAGE E500 Digital Camera
Remote camera function
Can I use the remote camera (PC camera) function with Macintosh?
    Master:
  • 425 Answers
No. Remote camera (PC camera) can be used with Windows computers only.
Posted on Sep 19, 2005
APEX K12K-C5 UNABLE TO have remote turned with new batteries. need a manual for the above product.
Here's an interesting trick to test if the remote has functionality - use the camera function on your phone and aim the remote towards the camera while trying out the buttons. The camera is infra red sensitive and it will appear as a white light on your phone screen if the remote is working.
Sep 07, 2018 | Televison & Video
I HAVE MODEL LCT3201TD. I AM USING THE REMOTE THAT CAME WITH THE UNIT. THE REMOTE WILL TURN THE UNIT ON AND OFF,CHANGE VOLUME AND SLEEP TIMER. TO CHANGE CHANNELS I USE A SEPARATE REMOTE. I WOULD LIKE TO...
The tv remote that came with the tv unit.The tv remote might have channels buttons up/down buttons functions and numbers pads might be shorted and dead and no longer functions anymore.U have a Digital Camera turn it on take the tv rmote put in the front of the Digital Camera pushes each buttons one by one all the buttons that work u will able to see a flashing white light on the camera vewing screen,because the Digital Camera can read INFERED input signal to see a output u see on the the camera viewing screen.After u test it on the front of a Digital Camera any buttons don't have a white light flashes INFERED read out than those buttons functions are shorted and dead.Try website like Remotes.com to buy the tv original remote to replace and used.
Aug 29, 2011 | Akai LCT3201TD 32 in. LCD Television
I am using the AT8560 remote and my mute function does not work. Can you help me?
Ur tv mute button might not be function anymore,because of rubber inner layer are worn out or the main CPU chip of the remote itself it shorted causes this problems.U have a Digital Camera,turn it on.Put the tv remote wright in front of the camera press the remote mute button,u will see on the camera viewing screen the mute button work or not wright away because Digital camera can read infer red signal output.Try website like Remotes.com to buy a new original remote or a very closed compatible one.
Jun 13, 2011 | LG 42LC2D 42 in. LCD HDTV
Volume control on reciver isn't working. Only using remote control for volume works. So I must need a volume control for the receiver. Is this an easy fix or not worth the time to fix
Hello
You haven't specified if all the other functions are working with the remote control or not. If no functions are working with remote control, either there is no infrared emission from your remote control handset. Check it with the help of a cellphone with camera option. Cellphone digital camera can detect the infrared rays comes out of the remote control. Just put the cellphone to camera mode, and place the remote control just about 1 feet away from its camera lens and push each button on the remote control and see whether there is any image of infrared rays indicates at your cellphone camera screen. If not, be sure that the remote control is not working, and should be replaced or repaired. Replace the cells first, and check. If this does not helps you and still the remote control is not working, replace it.
If the remote control works, and the all the other functions of your device can be set with it, the motor of the volume control or it control circuitary has damaged. To check this, you must have through knoledge in electronics and is a time taking service work. OK.
Apr 24, 2011 | Sherwood RD-6500 Receiver
My standby function does not work, i have changed the Batteries in the remote, and still it does not work, any Ideas?
Hi, I assume you to mean that only the standby function on your remote does not work but all other functions are Ok.
If this is the case, then the remote most likely needs to be disassembled & the contact pads/circuit board need to be cleaned. use isopropyl alcohol for this.
You can test the operation of the remote using any digital camera/cellphone camera to view the IR led in the front of the remote
Sep 23, 2010 | Toshiba REGZA 47HL167 TV
Remote control doesn't work even with new batteries
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
Jul 25, 2010 | Philips 32PF5531D 32 in. LCD Television
I sat on my remote and now it doesnt work is there a way to reprogram the remote?
Check if the remote is still transmitting. You can do this with a digital camera. Point the Remote at the camera's lens then start pressing buttons on the remote. If you see a blinking light from where the remote transmits on the digital camera's LCD screen, the remote is functioning properly.
If you do not see it transmitting, replace the batteries. If it still does not work, the only thing you can really do is get a new remote, there is no way to reprogram the LG remote. You can get a universal for for pretty cheap or you can contact LG to get the exact replacement remote for your TV to ensure it has all the functions needed.
Oct 09, 2009 | LG 42LG30 42 in. LCD HDTV
JVC Everio GZ-MG145 backup on mac - files are .mod
The software iVerio might help you. It transfers and converts automatically all your videos from your HDD camcorder.
Have a look on the site http://www.convertmod.com
Feb 21, 2008 | JVC Everio G Camcorder
Receiver not taking commands from the remote
Point the remote at a digital video camera to see if you can see the small blue infared light comming from the end of the remote when you aim it at the camera and press a button. if you do see the light then your receiver has a system control problem I'm afraid. You see your eyes cannot see the infared light but the camera optics can. Good Luck
Jun 07, 2007 | Onkyo TX-DS989 Receiver
Konica Minolta DiMAGE E500 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
