Most maytag dryers you cannot work from the back side. The old style dryer is accesed by removing phillips screws at the base of the dryer. The newer models use a putty knife to realease the top. Some models called slopefronts you remove the door and then the front to get to the innards. I have a page on maytag dryers which features videos and service manuals. MAYTAG DRYER PAGE
It depends on if its a newer model or not. If its not a newer model (usually with the controls on the front). Most of the time there are two clips under the lid in the front, take a putty knife or flat end screwdriver and push in on the clamps. Use flashlight to check to make sure the clips are the because without knowing which model it is its hard to know if they will be there. Pop up the lid and off to the left and right you will see 1 screw phillips or a 1/4 inch nut on each side. Than tilt the front panel back and lift up because it is on hinges. The drum may fall forward. Wrap the belt around the drum and around the pulley and motor shaft. If this is a true maytag than putting the belt on will confuse you because the belt has to go around the pulley backwards. If you get stuck please contact me.
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
Belts are usually replaced fromt eh back service panel, but often it helps if you "pop the top". Put a screw driver in the seam at the front corners and pop the top upward. It will hinge at the back.
Go to repairclinic.com and click on the "Repair Help" link. On the following page, look for the "Dryer Belt Diagrams" link under the Special Features section. Scroll down to Maytag (diagram E). I hope this helps you.
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
you cant take back cover off, you remove front cover and then access the top cover then you can replace the belt,there is an access panel on the rear you may need to remove to put belt on motor and idler pulleys
type 1:older models by Maytag with lintscreen under door
unplug dryer
remove 2 screws from under front panel
tilt front panel up from the bottom and unclip top
remove door switch wires
set front panel aside
remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
unplug dryer
remove lint screen
remove 2 screws under lint screen
with putty knife or other blunt blade unclip spring clips at front corners of top panel
tilt front panel up
remove 1 screw each side of front panel 1/2 way from top
remopve door switch wires
tilt front panel down and unclip
all
withdraw drum forward
examine drum rollers for wear if worn or locked replace in pairs
examine felts and nylon glides(if fitted) for wear if worn replace
examin case floor for tensioner (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
loop new belt around drum at wear mark of old belt
insert drum
loop belt around motor pulley
pull tensioner to end of travel against spring
loop belt around tensioner
relax tensioner
rotate drum by hand to make sure belt wont jump off
dont know if this will help or not
ribs go up .. flat part of belt goes against drum this has a crapping diagram of curve of belt
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=3048&modelDesc=ELECTRIC/GAS%20DRYER&modelNumber=PYE1000AYW&documentID=M0412160&documentTypeID=PLDM&documentClassCode=PV&titleType=TUMBLER&titleID=00004&
