Question about Eclipse AVN5500 Car DVD Player
Avn 50d i bought a used honda odyssey with avn 50 d but the navigatition sistem doesn't work say check cd the problem is we don't have tha cd can i find the cd anywhere?
  • Anonymous Oct 30, 2008
    tengo un eclipse avn 50d el problema es que no funciona pues pide insert map disk
  • chavez672008 Mar 11, 2009
    me pide la configuracion de map para k trabaje
Call 310 327 2151..ask for support..they're going to ask you for the original purchaser's name..and maybe his or her mother's maiden name..after that the'll walk you thru setting up another security disc for the system..takes about 10 min...just did it yesterday...
Posted on Sep 05, 2008
Honda odyssey 2003 CD player shows E 00 w hen I try to load cd
E00 is a vague error code used by Honda that indicates a problem with the CD Drive in the head unit. Unfortunately this will require removing and head unit and replacing it with either an OEM replacement or an aftermarket unit.
Apr 05, 2015 | 2003 Honda Odyssey
Honda odyssey 1999 codigo p1457
do they have reset botton for the starter
Apr 01, 2013 | 1999 Honda Odyssey
2005 Honda Odyssey left front power outlet doesn't work.Right one works fine.How do I fix
using a test light check the fuses in the fuse panel then check for power and ground at the socket. if one is missing remove the socket and check for power and ground at the electrical connector. if you have both the socket is bad and needs replacing. if you missing one you will have to check that wire to find were the problem is and repair it.
May 14, 2012 | 2005 Honda Odyssey
Where is the fuse fo dash lights
That info is in the owners manual, Honda doesn't make them avaiable for free downloading like American cars do so we don't have the info you need.
Feb 16, 2012 | 1997 Honda Odyssey
Check Engine Light on 2000 Honda Odyssey
what is the code that turned the light back on?????? if its a P0420, the cat is not good enough. you may need one good enough for California or a better quality converter.
Oct 22, 2009 | 2000 Honda Odyssey
2003 odyssey studders @ 50 -55 mph seems to studder more if i press on throttle then fall back to 50-55
1999-2003 Honda Odysseys have trouble with their transmissions. Google "honda odyssey transmission" and look at the wikipedia article that comes up for Honda odysseys. In about the fourth paragraph you will find out about the transmission problems. If your van is acting up, have the transmission checked out sooner vs. later. It won't get better on it's own. Have the diagnostic trouble codes retrieved from the car's computer--any code that starts with 17 as in "1740" or codes that start with zero like "0730" are transmission codes and signs of impending failure. I know because my 2002 with 165,000 miles just failed.
Sep 15, 2009 | 2003 Honda Odyssey
Modification problem
replace it with the original fuel delivery system would be the best way to go!! try a junkyard
Jul 12, 2008 | 1994 Honda Accord
Eclipse AVN5500 Car DVD Player Logo
617 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
