Question about HP iPAQ RX3115 Pocket PC
Can't get dynamic ip address
Okay.. here is the situation: Purchased an HP ipaq rx3115 and used to have WiFi internet working all fine with my home network. Then, I added some program (God knows what) that made the PDA not get an ip address from the router I have. I could manually type in a static ip and do it that way, but when I travel this is cumbersome and would like to have DHCP doing the job. When I take my "broken" PDA to my school it picks up a good IP and works fine. How do I fix the problem at home? Okay, before you respond, I have tried the following already: 1) made sure the router was sensing the PDA's signal and it is. I have MAC filtering for all my WiFi equipment because I don't want to make a security key. 2) have reset, hard and soft for my PDA 3) reset my router multiple of times and set it to have the default values.. which still picks up my PDA but won't give it an IP address - most likely my ROUTER because I can get a dynamic IP address at school. PLEASE HELP!! thanks..
  • 44 Answers
What about your desktop pc? Have you checked the services on it to make sure it is not broadcasting DHCP? Also, think about switching over to Stealth Mode (Non-broadcast SSID) instead of MAC filtering. MAC filtering can be cummbersome and if it is just you, then do away with it.
Posted on Sep 19, 2005
SOURCE:
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
Diffrent between Dynamic&static ip address
Static IP address is usually a single IP address provided by the ISP to you, which can be configured so that you can run a web server (host web sites etc), or access your home computer from any where in the world ( your computer and internet should be on ).
Dynamic IP address is usually IP address provided by the ISP to your DSL modem / computer (for dialup modems) for that internet session, next day or next time you connect the IP address will be a different one. (usually home internet connections are Dynamic IP based.
In a typical home environment if you have one wireless adaptor and planning for a wireless repeater its better to configure dynamic IP address in the repeater (so that you repeater will acquire IP address from the wireless adaptor)
Dec 09, 2010 | Computers & Internet
Why i cant connect to internet my hp ipaq rx1950? i have my network fine and i can use with laptops i dont understand what happen?
Check... For Wifi On/Off Swich, also check for your Wireless IP. Connection Statut.. Make Shure it wile Conected with the same IP
Check your Firewall configuration...If So re-install your Drivers & Softwares...Save all your personal infos first... Good Luck.
Oct 06, 2010 | HP iPAQ rx1950 Pocket PC
Can't get my son's hp Mini to connect to our router. Secured or not. It has worked on other routers before.
My guess would be that the 'dynamic' IP address cannot be resolved properly on your home network: try using a Fixed/Hardcoded IP address in TCP/IP Internet Protocol for your son HP Mini. Let me know how you go.
Dec 31, 2009 | Linksys Wireless-G WRT54G Router
Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
I went and got static IP addresses from internet provider...Must of caught them on a good day
Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
HP rx3115 hard reset
Had the same problem with my hp rx3115 . Worked fine, then the next day dead. power button, lower buttons, or outter reset button didn't work to turn it on. Okay so, i thought it just needed to recharge. Used computer cable for active synchronizing that also recharges, still dead. Then cable just for recharging. Finally comes on. Charged it all the way up, synchronized it, unplugged it, few minutes......dead. The battery is no good.
Nov 16, 2007 | HP iPAQ RX3115 Pocket PC
HP iPaq Rx3115 ...Please Help..
It depends what quality you need. If you need top quality you will have to go for something else like a dell axim x50v. This PDA should be ok for watching a movie as long as it is encoded properly, at a low resolution that is.
Sep 15, 2005 | HP iPAQ RX3115 Pocket PC
Slow SD Speed
Use the site For the Ip-Address Details http://www.ip-details.com/
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
Using hotspots with my rx3115?
It's the same settings as you would use for your home network. When you are connected and you start Internet Explorer , you will automatically be prompted to sign in or register for an account. Some Hotspots are free, and you will not have to go through this account page.
Sep 07, 2005 | HP iPAQ RX3115 Pocket PC
Connecting RX3115 to Laptop w/ WiFi
you have to configure an ad-hoc connection between ipaq and pc if no router. otherwise, simply connect to the router and run activesynch
Open Questions:
COMCAST password reset phone number +1800 828 0294 RAJAN RAJAN Get COMCAST 1800 828 0294 password reset phone number easy steps to forgot or change COMCAST password reset via phone number #1-************ just follow some steps to recover COMCAST password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure COMCAST with COMCAST or other microsoft account services. Their are many certified officer to suggest people that how to change or reset COMCAST voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to reset COMCAST password to reset or change it quickly, if you have any of them so contact to get well COMCAST support form us. COMCAST password reset not working COMCAST password reset phone number COMCAST password reset contact number COMCAST password reset help COMCAST password reset support COMCAST password reset wont work COMCAST password reset wont work COMCAST password reset link COMCAST password reset issues COMCAST password reset usa COMCAST password reset customer service. COMCAST email account password reset ' free COMCAST email password recovery ' cannot reset COMCAST email password ' COMCAST email password recovery ' COMCAST email password recovery download ' COMCAST email password recovery software ' free COMCAST email password recovery. COMCAST email password change, COMCAST email hacked password changed, COMCAST email hacked can't change password, change COMCAST email password on iphone, change COMCAST email password on ipad, change COMCAST email password on android, COMCAST email account hacked can't change password, how to change COMCAST email password on droid, COMCAST email password problems, COMCAST email password not working, COMCAST email account password reset. COMCAST password reset phone number.
Apr 26, 2019 | Microsoft Computers & Internet
AIM password reset phone number +1800 828 0294 RAJAN RAJAN Get AIM 1800 828 0294 password reset phone number easy steps to forgot or change AIM password reset via phone number #1-************ just follow some steps to recover AIM password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure AIM with AIM or other microsoft account services. Their are many certified officer to suggest people that how to change or reset AIM voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to reset AIM password to reset or change it quickly, if you have any of them so contact to get well AIM support form us. AIM password reset not working AIM password reset phone number AIM password reset contact number AIM password reset help AIM password reset support AIM password reset wont work AIM password reset wont work AIM password reset link AIM password reset issues AIM password reset usa AIM password reset customer service. AIM email account password reset ' free AIM email password recovery ' cannot reset AIM email password ' AIM email password recovery ' AIM email password recovery download ' AIM email password recovery software ' free AIM email password recovery. AIM email password change, AIM email hacked password changed, AIM email hacked can't change password, change AIM email password on iphone, change AIM email password on ipad, change AIM email password on android, AIM email account hacked can't change password, how to change AIM email password on droid, AIM email password problems, AIM email password not working, AIM email account password reset. AIM password reset phone number.
See all HP iPAQ RX3115 Pocket PC Questions
HP iPAQ RX3115 Pocket PC Logo
454 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
