Question about LG LSC26905TT Side by Side Refrigerator
Water leak A water tube inside a spring is cut and doesn't apear to be repairable, the door does'nt come apart.Hopefully there is a solution.
  • 166 Answers
Service is the solution! only they will be able to help you with hands on repairs!
bless you,
Please rate me before you sign off!
Posted on Sep 05, 2008
Need to replace water line inside freezer door.
Water lines inside doors are typically not serviceable as the insulation is "foam in place". Pulling apart the door and reassembling will be next to impossible. Generally the door would need to be replaced.
Apr 14, 2014 | Samsung 24.8 Cu. Ft. Side-by-Side...
The rubber gasket around the drum opening is leaking and rusting
You can replace it by lifting the lip of the rubber around the edge and finding the wire where the springs connect there you can stretch the springs apart, remove the wire and pull off the rubber. Just make sure first that is where the leak is, sometimes a leak in the soap dispenser water tube can seem like door gasket leak.
May 16, 2011 | LG WM2277H Front Load Washer
Have a GE hot point HSS25GFTABB, removed doors to put inside house after a move and the ice maker works, but when you fill with water, it runs down the line dripping at the bottom of left door
Inspect the line crefully at the bottom of the door where it connects to the cabinet supply. The line may have been damaged when and if the doors were removed.
HOPEFULLY it is a small nick in the tubing casuing the water leak, and not the line inside the freezer door as the water line is foamed into the door and the entire door would have to be replaced to resolve an internal leak.
The coupler at the door connection is a push-lock syle coupler and to seperate the line you need to press the white collar into the blue barrel connector to relese the tension.
Jun 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kinetico water filter leak
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What you are describing sounds like a quick connect fitting. I have included a link below to a video that explains how this type of fitting works. If you are using plastic tubing with these fittings you may be able to remove the tubing from the fitting and cut back about ½” from the end of the tubing and reinsert it into the fitting. Do not cut the tubing with scissors, use a tubing cutter or razor blade knife (see video). If that doesn’t solve the leak and you find that you need to replace any fittings we have a complete selection located here:
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - 1.877.335.3339
Mar 16, 2010 | General Electric Profile Smartwater Ultra...
My washing machine is leaking from the bottom it is ruining my floor do I need to replace the machine or do you think it is a simple task to fix
If this is the same leak I just fixed, it is worth fixing ($12 dollar part from, but takes some skill at taking it apart and putting it back together.
My leak was from a black rubber hose that connect the drum to the filter area and recirculating and drain pumps. The repair can be done from the front of the machine.
1. Drain the machine - pry the panel at the front left lower corner to get access to a stoppered tube. drain as much water from here as possible.
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right (there is a wire connecting the door to the machine on the right)
7. You can now see inside the machine and hopefully see where your leak is comming from. The black rubber hose connecting the drum to the drain area is where my leak developed because this is designed to flex as the machine tumbles and spins but ultimately wears out. It is connected with two clams that can be removed with pliers and a third hose clamp that diconnects with a phillips head screw driver.
Apr 26, 2009 | LG WM-2277HW Front Load Washer
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
LG LSC26905TT Side by Side Refrigerator Logo
100 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
