Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Door not closing
The refrigerator door does not close - it happened this morning - we were surprised, as this never happened before..it seems that the rubber gasket has lost its magnetic attraction...
please could you suggest what needs to be done...
Your suggestions and help will be highly appreciated.
Thank you,
Philip
905-492-1780
09/03/08
  • Phily boy Sep 05, 2008
    Thank you,
    Philip
    905-492-1780
    09/03/08
    Genius:
  • 1,027 Answers
Usually the gasket does not lose its qualities; I would check along the hinge line, to see if the gasket has pulled loose, and is causing the binding. It can be poked back into place, or glued (only on the door side).
Posted on Sep 05, 2008
Refrigerator light won't turn off
Either the doors are not closing properly, or the door-light switch is bad. Though I would not be at all surprised that it is a more complicated issue such as a motherboard since it is an LG (low grade) refrigerator.
Jul 28, 2010 | LG Refrigerators
Trap door for ice does not close all the way
This happens from time to time. There is a kit to replace the door flap assembly. It isn't to awfully hard to replace. Post a model number and I can tell you what part number you need to order :)
May 31, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 16, 2009 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator Door won't stay closed
Part 12 on this diagram is your cam. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSRB27FHSS02&productCategoryId=0165000&brandId=0593&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00006&componentDescription=REFRIGERATOR%20DOOR&documentId=O2030395&backToLink=Return%20to%20Sub%20Components%20list
Aug 19, 2009 | KitchenAid KSCS25FKSS Side by Side...
Door on refrigerator won't close and stay closed. Seems as if there is no magnetic seal and this just happened all of a sudden. The seal around door is not cracked or old. Freezer side is OK.
You will need to replace the gasket. The gasket seems to have failed and that is where the magnet is. You can try to clean the magnet surface and the door surface with rubbing alcohol but you are most likely going to need to replace the gasket
Apr 28, 2009 | GE GSH25JFR Side by Side Refrigerator
550 Door Seal Doesn't Seem to Be Working
Since the doors on most refrigerators are adjustable, check the alignment of the door by pushing it close to being closed and seeing if the crack still visible is consistent around the three sides not yet in contact with the frame. These normally don't change much over the life of the unit but you may be able to improve the contact through an adjustment. Considering that the door does not seem to want to stay closed, check too on the hinge side to see if that part of the gasket is striking the frame too early.
Jul 23, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Dec 28, 2007 | Whirlpool GS6SHAXMQ Side by Side...
Light stays on when door is closed
The GE GSL22JFPH refrigerator door gets lower over time. When it gets low enough the light stays on when the door closes. There is a vertical bolt along the hinge line. Push down the hinged plastic "hinge cover" under the door right on the hinge line and you can get a wrench on the bolt to raise the door. I have to do this every 6 months/
Jan 18, 2006 | Hoover HCA331FFK
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
70 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
