Question about Konica Minolta DiMAGE E500 Digital Camera
What is the frame rate of the remote camera (PC camera)?
    Master:
  • 425 Answers
The maximum frame rate is 20fps. (Approx.)
Posted on Sep 19, 2005
Help w/ quantaray 10.4 digital picture frame
pls backup ur data & reformat ur sd card to fat 32 using ur pc
Jan 05, 2014 | Quantaray Photography
How can i use the motion eye camera to capture picture? only video recording is the one i can use.. please help..Thanks
Frame rate is also a term used in real-time computing. In a fashion somewhat comparable to the moving-picture definition presented above, a real-time frame is the time it takes to complete a full round of the system's processing tasks. If the frame rate of a real-time system is 60 hertz, the system reevaluates all necessary inputs and updates the necessary outputs 60 times per second under all circumstances.
Owing to their flexibility, software-based video formats can specify arbitrarily high frame rates, and many (cathode ray tube) consumer PC monitors operate at hundreds of frames per second, depending on the selected video mode. LCD screens are usually 24, 25, 50, 60, or 120 FPS.
The designed frame rates of real-time systems vary depending on the equipment. For a real-time system that is steering an oil tanker, a frame rate of 1 FPS may be sufficient, while a rate of even 100 FPS may not be adequate for steering a guided missile. The designer must choose a frame rate appropriate to the application's requirements.
http://www.mercedesbenzwheel.com
May 23, 2012 | Computers & Internet
I record all of my videos in a frame rate of 29 frames per second. How can I change these videos to real time?
29.97 frames per second is the default frame rate for most video cameras. This video will play back just fine on any computer or television. If this does not answer your question, please clarify your issue in a reply.
Thanks.
Mar 08, 2011 | JVC Cameras
I downloaded driver of frontech e-cam JIL-2217 but everytime i have to uninstall and install it agin
PC camera china made,CMOS image sensor USB type,hi-resolution:640*480.24bit RGBS/N RATIO 48dB
frame rate 302*240 up to 30 frame/sec/(
cif)
i have problem in which whenever, i conect with yahoo massenger and on cam, no pic on frame and conectivity,but when i give vedio call a small pic come on frame(ony pic come when give vedio call)
Jan 03, 2010 | D-Link DCS-5300 Network Camera
How to connect to remote camera
To create new Camera Window
  • Click New Camera from the File menu.
  • Camera Setting dialog box appears.
Camera Setting dialog box helps you control selected video source. To open the Camera Settings dialog box, select Camera Settings from the File menu.
Set a preview rate in the Preview Frame Rate box. It indicates the number of frames per second in the camera window. The default value is 10 frames per second. This value doesn't interfere with broadcast or record frame rate.
Remote Cameras
Remote camera is another Active WebCam program with enabled Remote Access launched on remote computer. Both programs use UDP protocol to communicate each other. If connection with Remote camera goes through firewall, make sure that the IP address of your computer, local and remote ports are opened on the firewall, and the UDP protocol is enabled.
To connect to Remote Camera
In the Device tab click to select Remote Camera.
Specify the computer address in the IP address box. Don't place the protocol prefix (like http://) in the address, just four digits of IP address delimited by dots, like: 192.168.1.101. You can find out the remote computer IP address by clicking Get Computer IP Address from the Tools menu on the remote computer.
Type port, which is opened on remote computer for remote access in the Remote Port box. This value is specified in the Port box in the Broadcasting | Remote Access properties on the remote computer.
Specify port, which will be used to receive data from remote camera, in the Local Port box. If your network uses firewall, make sure that Local Port and computer's IP address are opened in the firewall. Use the Check the Port Availability button to make sure that this port is not used by another program.
If the remote computer requires authorization, enter user name and password in the appropriate boxes. The authorization could be set in the Broadcasting tab in the Camera Settings window in the Remote Access Additional Settings window on the remote computer.
If the Remember Password check box is checked, the user name and password will be saved among the session parameters.
Cycle through cameras
If you have multiple cameras you can set up a cycler to have the program to change cameras automatically.
To configure the Camera Cycler:
  • Click Camera Settings from the File menu.
  • Select Cycle through cameras to activate cycler.
  • Type cycler interval in seconds.
Select cameras to cycle.
Jul 13, 2009 | HP USB Web Camera
Need help importing from Tag Folder to internal Digital Frame dri
You could try 'import from camera', see if the frame accepts the folder on your PC as the memory of the camera.
Jun 14, 2017 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Web Veiwing Problem
Is your internet connection high speed? Also, is the recipient's computer an older computer with little memory and processing power?
Nov 04, 2008 | MSI Starcam 370i Webcam
Frame rate of movie file
The DiMAGE E223 can capture a movie at 15 frames per second. When a movie is captured while the video output is used in PAL mode, the frame rate is 12.5 fps.
Sep 19, 2005 | Konica Minolta DiMAGE E223 Digital Camera
Konica Minolta DiMAGE E500 Digital Camera Logo
24 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
