Question about RIM BlackBerry 7105t
Hourglass symbol on a white screen
My blackberry won't start up. all i see is a white screen with an hourglass on it.
  • 2 more comments
  • Trabes Jan 09, 2009
    I have a white screen and an hourglass I have taken out the battery several times with no luck. HELP!!!
  • Anonymous May 13, 2009
    I was sending a picture and it timed out. I took the battery out and started it up after a few minutes and it just has the spinning hourglass with a white screen...
  • dfwlori May 11, 2010
    What is a hard reset?
  • Ch3ryl May 11, 2010
    If I do a hard reset will I lose all my contacts and pictures?
You can do a hard reset
Posted on Sep 05, 2008
My bb screen is all white and I cannot turn it off as well. Please help
First of all what you need to do is to perform a reset on your BB by hitting ALT+RIGHT SHIFT+DEL your blackberry will reset itself. It will go black for about 2 to 4 seconds then you will see the famous blackberry hourglass. Be patient and in about 2 to 5 minutes your blackberry will reset.
ALT+RIGHT SHIFT+DEL can be used for continuous hourglass issues, JVM Error 200 "White Screen" to name a few.
If that does not work then you should perform a battery pull by just pulling out the battery out of the phone while it is on this is also a reset option.
Go to your service providers website, download the software from there, and then install it on your pc. Once done, delete the vendor.alx(xml file) file, open Desktop Manager (DM), connect the BlackBerry, and follow instructions
Apr 20, 2011 | Computers & Internet
The screen whites out n only way to get it back is take battery out n let it start back up
Hi there
Whenever your screen goes white again just hit the ALT+RIGHT SHIFT+DEL your blackberry will reset itself. It will go black for about 2 to 4 seconds then you will see the famous blackberry hourglass. Be patient and in about 2 to 5 minutes your blackberry will reset.
Try freeing up some space on your blackberry by deleting some unecessary files and do not run too many applications at once.
Oct 11, 2010 | RIM BlackBerry Curve 8310 Smartphone
Hi , i bought a curve 8520 3 weeks ago and it has been brill ,however last night the screen went white wiv the hourglass..i hav took the battery out for several hrs..and then replaced it...and my phone...
The BlackBerry has the feature on auto-start. When you insert the Battery, the device will automatically boot-up. It'll be showing an hour glass while loading the settings. But if it is longing for more than 10 minutes, there might be some error in the OS. It's better to contact a near-by authorised Service Center.
Vineeth K.
Aug 05, 2010 | RIM BlackBerry Curve 8520 Smartphone
Curve with white screen with hourglass and red light on
If the flipping hourglass stays for longer than 2 min our Blackberry may just need a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings.Download the Blackberry Desktop manager and run the application loader. Make sure you check to delete old applications in advanced tab. Carefully all you datat will be wiped.
Aug 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
Hourglass of death need help
have you tried downloading and reinstalling the handheld software? if not the phone probably needs to be replaced.
Aug 03, 2009 | Sprint BlackBerry 8703e Phone
8310 BlackBerry start-up symbol
you must fullflash your BB to work it can use desktop manager 4.7 to flash your phone.
and here you can download firmware:
Jul 25, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve won't turn on...
Wipe it to start over. Sometimes when you change or add something like a THEME or a download it HOSES the BB completely. So delete what was on there and don't download a theme or any other wacky add-on.
To Sanitize or Clear out all the information in a Blackberry Device
Scroll to select the OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY and press [Trackwheel] to select.
On some units you may have to select GENERAL SETTINGS before getting the next menu.
Press [Trackwheel] again to access the Menu screen for the security.
Scroll to select the WIPE HANDHELD and press [Trackwheel] to select.
Scroll UP to select CONTINUE and press [Trackwheel] to select.
Type blackberry on keyboard to confirm the action press <-| key.
System responds with ERASING INFORMATION.
Mar 19, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My blackberry 8700 will not come on completely. first - white screen comes up, following with the hourglass., then black screen comes up and LED ligt flashes red and then shuts off and then...
Hi Sam,
It is normal for Blackberry to load all its applications which takes few mins. However in your case the BB shuts off. I would suggest downloading the latest Device Firmware from, and update your device with that firmware to your Device using the Desktop manager on your PC.
If not firmware then, check your device battery..
I hope this helps,
Jan 31, 2009 | RIM BlackBerry 8700c Cellular Phone
Blackberry 8100 screen wont work
check your display! i think display is problem in your mobile! IC fault in display!
Jul 10, 2008 | RIM BlackBerry Pearl 8100
Constant hourglass symbol-draining battery
Hi, this is called the hourglass of death, the device is stuck in a reboot cycle.
You will need to reload the applications, but you can't use Desktop manager because the device resets and the connection drops.
First make sure the BB is unplugged, then go to Program Files > Common Files >Research In Motion > AppLoader and run loader.exe. Click next, it will say port : COM PORT 1 now is the tricky part you have to plug in the BB and COM 1 will change to PIN: UNKOWN , when this happens you have to quickly click next before it reboots again, then it will ask for pin and now has an connection with the device so you can go ahead and re load all the apps.
Good Luck
Apr 16, 2008 | RIM BlackBerry 7250
Computers & Internet Logo
507 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
