Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser the water continues to run after dispensing, i have to shutt off the supply in order to stop it, this works until someone forgets and uses the water again. I ahev ge model gss25lgpa . Thanks
This sounds like the microswitch that is activated by the paddle is sticking . If all the other functions appear to work ok ?? Does this particular model have an ice and water dispenser ?? Does the ice behave in the same way ? if not then i would suggest that the water valve is not closing and needs replacing instead of the microswitch
Posted on Sep 08, 2008
CWTF15 WILL NOT STOP WATER FLOW WHEN POT IS MADE.
The coffee dispensing valve is stuck open. It may be due to Calcium deposits.
Descale the machine or manually clean the dispensing valve and the diffuser disc that unscrews to be removed. This diffuser is visible just above the coffee pot.
Oct 16, 2014 | Bunn CWTF15
Howto repair refrigerator water dispenser
There is an electric water valve, usually at the lower back of the appliance which would appear to be stuck open and would need to be replaced OR the switch in the dispenser area is stuck in the closed position. Try disconnecting the wiring to the valve and if that stops it then most likely the dispenser switch is defective, If not then the valve is likely stuck open. There should also be a small valve in the water supply line, under a sink or etc. that you can shut off to stop the water flow with until you get the other problem daiagnosed and fixed.
Sep 08, 2014 | Hotpoint Refrigerators
Door dispenser drips
I am assuming when you say the door dispenser drips, that you mean the water dispenser. I had the same problem with my Samsung fridge Freezer, it just turned out to be that the water pressure from the tap supplying the dispenser was turned up too high, the advice I was given (from an engineer) was to turn down the pressure a little then run the dispenser for approx half a litre, then let it sit for a while to see if the drip continues, if it does, try again, it took a few adjustments but we're running fine now, but don't forget, it's normal for a dispenser to drip once or twice after its use. Good luck.
Jun 17, 2012 | Samsung RF265AA Bottom Freezer French Door...
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Water dispenser dripping water all the time
First be sure the refrigerator is connected to a cold water supply. After connecting the refrigerator to a water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, and then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 12 L has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system, water may spurt out of the dispenser.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Hope this will be useful.
Thank you
Jan 04, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water continuouly run out and overfills the cup
Water continuously running from a water dispenser is caused by a leaky water inlet valve which is on the back where the water supply is connected. It needs to be replaced.
Unless the dispenser switch is stuck. When you depress the switch you should hear the water inlet valve open and it should stop when you release it.
Nov 05, 2010 | Refrigerators
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Stuck Water/Ice Dispenser LG LRSC26920TT
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
Aug 18, 2009 | LG LRSC-26922 Side by Side Refrigerator
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
224 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
