Question about Prima CV2011 TV
Television My wife turned off the tv with our universal remote the same way she does every night. When she turned it on the next evening there was no volume, but on the tv it shows the volume level as going up and down. We called bell satellite com. and he told us to switch our cable from our tv in the bedroom and if that didn't work, then there is something wrong with our volume in the tv. It is a 21 inch prima tv we have only had for 6 years. we have tried everything possible; even with the original remote from the tv but nothing seems to work. And in that case what must be replaced in the tv to fix the problem and is it worth it.
  • Vitally Alcher Aug 28, 2013
    after 5 years , a prima tv , you should get a new one . A Samsung HDTV LED , 3D , WITH SURROUND SOUND .
    Genius:
  • 1,027 Answers
The TV's sound amplifier has failed - needs to be service.
Posted on Sep 05, 2008
Which universal remote is compatable
you should be able to set up any universal remote to your TV.
as you did not note what television can can't tell you what remote will work best or have more available functions on the remote, but you should be able to get any universal remote to turn on and off the tv, change the channel with the up and down buttons and adjust the volume.
try each code in the universal remotes manual to see which one works best. NOTE: the first code you get to work may not work as well as the next, so if some function does not work you are looking for, try the next code. If you get a universal remote with code search function that is even better as you can using the remote to figure out the best code match.
good luck, and if you have probablems getting your remote to work, post a comment what tv you have and what remote so we can better resolve your issue.
Jul 02, 2011 | Televison & Video
Parental Code Unlock for ORION Model No. STV2763
If you have the original remote, or a universal remote with number buttons that show up on the screen, you can call the cutomer service number on the set for help deactivating the v-chip.
Oct 30, 2008 | Orion1934 19" TV
Can't turn subtitles off
Hmm... have you tried ontop of the remote where it has "tv" vcr" sat" etc...hit tv first then try the menu?and do you have satelite by any chance? because something similar happened to me when i had my old tv put upstairs and hooked up, the remote for it did not work so i had a universal and the tv was on "video 1" input the whole time and the universal remote didn not convert it back to tv so what i had to do was hook up the reciever to the "video 1" port instead of the "tv" input in the back...i hope you get it cause i know it can be a pain in the A$$
Sep 13, 2008 | Televison & Video
Universal Remote for this TV?
I usually recommend a GE universal remote... They are known to work for even the most stubborn televisions. I have no problem making sure you have the right code for your TV
May 04, 2008 | Quasar VV2507 25" TV
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Sony TV won't turn on :-(
our power went off last night for three min and when it came back on we could not get one channel. this morning my wife turn on our television and it worked fine. my wife went to turn it on tonight and it will not come on from the remote or at the bottom of television
Nov 08, 2007 | Televison & Video
Television "locked"
Yes only the original remote will unlock it. 10 out of 10. I have unlock it also with Ellis universal but buttons is not the same.
Sep 14, 2007 | Televison & Video
NEED HELP !!!!! remote will not work (original nor directv programed)
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Sep 14, 2007 | RCA 36V550T 36" TV
ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
May 23, 2007 | iLO 3200 32 in. LCD Television
Prima CV2011 TV Logo
166 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
