Question about Janome Memory Craft 9000 Computerized Sewing Machine
Parts for Janome 3022
Where can I get a bobbin spool threader for my Janome 3022, without going through a repairman?
2 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: bobbin for janome model 3022
You need Janome bobbins for this machine........@ any dealer
Posted on Nov 27, 2011
Bobbin winder not winding cotton on spool a part has fallen in side machine how do l take casing off Janome 480 quilter thank you
Am unable to help with your machine but you can purchase a stand-alone bobbin winder called Sidewinder for about $30. Just be sure to verify that your machine bobbins will work on it. The one I have will use either a power cord or batteries. Great little machine because it saves wear-n-tear on the machine plus you can wind bobbins without unthreading the machine.
Customer Reviews Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Portable Bobbin Winder
Amazon com Simplicity SideWinder Portable Bobbin Winder
Jun 05, 2017 | Janome Sewing Machines
How can I get replacement parts (bobbin spindle cap & spool spindle) for a Sweda StitchMate hand held sewing machine?
The parts for this may be purchased on Ebay but it may be diffficult to purchase it else wheres. Give this a try though.
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
Mar 02, 2015 | Sewing Machines
Automatic needle threader stuck
You may have a thread stuck in your bobbin area. Remove your bobbin, brush gently with a clean soft brush to remove dust and/or thread bits, then gently wiggle your hand wheel back and forth, and brush again. This should free up your machine.
Jul 09, 2014 | Janome Sewist 500 Sewing Machine
Finding equivalent
I can't seem to find a decent picture of the Kenmore 385.16120200, but from the replacement parts that I can see, it may be close to this one:
http://content.janome.com/index.cfm/Machines/Sewing-Quilting/2212
Or maybe:
http://content.janome.com/index.cfm/Machines/Sewing-Quilting/Magnolia_7318
Janome is an excellent brand, and any Kenmore built by Janome is going to be just as good, but a little less expensive. However as the Kenmore sewing machine line seems to be hard to find even used, and if you are considering buying a Janome, I would highly recommend a few features to you:
Drop-in Bobbin, One-step Buttonhole, Automatic Needle Threader, and maybe (depending on your tastes and preferences) a few electronic features like Needle Up-down and Push Button Stitch Selection. If at all possible, go into a shop and try before you buy. Hope you find what you are looking for!
May 04, 2014 | Kenmore Sewing Machines
Janome j3 20
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Mar 01, 2014 | Sewing Machines
Bobbin for janome model 3022
Nov 16, 2011 | Janome Memory Craft 9000 Computerized...
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Janome MC11000 - my bobbin case becomes dislodged
My bobbin case was jumping all the time...had it in for repairs and would bring it home and even though the tech had attached a test sew piece with different colored bobbin and top thread I could not get it to sew without the bobbin jumping. I thought that he had lied about that being sewn on this machine...finally, I found that you should start with plenty of thread in your hand when threading machine...so that once you feel it click into the tension...DO NOT PULL the thread, it pops it out of the tensioner...just loosely thread and hold tension with your thumb and forefinger while using the needle threader.
Feb 14, 2010 | Janome Memory Craft 10000
I now have diminished eye sight but still enjoy sewing. Is there a machine that has an automatic threading system, and will also wind a bobbin without having to remove the bobbin?
try janome uk 0161 666 6011 they will be able to help they do some machines that have a threader
they are very helpful. mary h
Jan 05, 2009 | Brother CS-80
LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
May 12, 2008 | Janome 8080 Computerized Sewing Machine
Janome Memory Craft 9000 Computerized Sewing Machine Logo
78 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
